Best battery for the buck?
   / Best battery for the buck? #1
VT365
Who's battery is the favorite for a "Tractor" application? Advance auto, Auto zone, napa, Interstate, Exide, and plenty others. Should I look for a commercial rating or will any suffice?
   / Best battery for the buck? #2
I'm really stuck on optima batteries. I don't care how old the battery is in anything new I get, I replace it with an optima. I've never had one go dead and never had to replace one yet. No more corroded batter terminals, no more leaking acid and they even start my diesels up fast as ever no matter how cold it gets.
I used to be stuck on diehards till the came out with these. Sears sells them under their name now too but I believe it's interstate that manufactures them. They do sears batteries too last I heard.
You probably don't want my opinion on those other store brands.
   / Best battery for the buck? #3
WTA,
How long have you been using the Optima batteries? Do you have any long term experience with them, or just recent experience?
My VW TDI is going to need a new battery real soon...:rolleyes:
   / Best battery for the buck? #4
I have recently switched to Optima batteries after hearing nothing but great stories over on the boat forum I frequent. I switched 2 years ago. Until then, I was killing 1 boat battery a year. The others just couldn't stand up to the pounding/vibrations from the boat. I have been switching everything I own over as they die. I'm sold on them. Red tops for my vehicles. Blue top for my boat. I may put a blue-top in the tractor when it does because of the abuse it sees (although, my Jeep Wrangler abuses the red top pretty good).
   / Best battery for the buck? #5
xlr82v2 said:
WTA,
I wish I had a TDI. It sure would be easier on my 120 mile a day commute, wallet than my 18 mpg Wrangler :)
But, the Jeep is paid for, and runs like a top. Until it dies, I can't justify replacing it.
   / Best battery for the buck? #6
I've had good luck with AutoZone batteries. That's all I've had in my 25 year old Benz, after the original failed at around 6-7 years.
Think my first replacement battery in my VW was from Advanced though. Interesting that it was labeled as coming from Mexico. That's where the VW was made.
Ralph
   / Best battery for the buck? #7
I have a red top Optima in my Jeep that is four years old, if it goes six years then it will beat a Interstate battery I had once in a pickup.
I usualy only get @ 2 - 4 years on a battery.
   / Best battery for the buck? #8
[ begin hijack]
xlr82v2 said:
WTA,
I don't believe any Optima has the current rating that the TDI requires. Lots of discussion about it on the TDIclub.com web page. My TDI is also in need of a battery, hard to find one properly rated. Interstate has one... $190!! Still looking. [end hijack]
   / Best battery for the buck? #9
I've been using the NAPA gell-filled batteries for replacements near 4 years now. I have 5 on the job at this point. Nothing but praise for them. Just don't use a gell battery in anything proned to over-charge. That's bad on any battery but downright dangerous with a NON-VENTED gell battery.
   / Best battery for the buck? #10
We started using the Optima red-tops in my bro's 69 Coronet wagon about 5 years ago. That one worked out so well, what with being used only a few times a year, that we next installed one on the 68 Barracuda, then one in the 94 F-150 (they spends months on end sitting idle). If I ever get my Dart back on the road, it will get one, & when the battery goes on my 04 Colorado I'll see if one will fit it.
As far as wet-cell batteries go, there are only like 3 battery manufacturers in the US that make all those different "name brands." There's really very little difference in batteries, no matter who's name is on them. The biggest differences are in how well the plates are supported in the case, & how high off the bottom of the case the cells are.
2008 Pierce Enforcer Ladder Fire Truck (A55852)
2008 Pierce...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2017 TROXEL 150...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
Utility Trailer (A52377)
Utility Trailer...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Harris Kayot Boat with T/A Boat Trailer (A55853)
Harris Kayot Boat...
