Best budget spray gun setup
   / Best budget spray gun setup #21
any air compressor will work... or rather should work....
i tend to use portable tank. ((fill air tank up take it to trailer, vehicle, tractor, etc...)) that is to far away to connect electrical cords / air cords to fill up a tire.)) i picked up a couple extra fittings to turn the portable tank. into an "in line tank" when needed. so i can obtain some extra gallons.
the portable tank i want to say is 7 gallon maybe 10 gallon tank. + 1 to 7 gallon tank is on the air compressor (pending on which one i am using)
when painting the house. the extra tank gallons was needed. large areas covered quickly. and then you would need to wait a little bit for air compressor to get the pressure back up. the extra tank gallons made things reasonable.
on smaller projects say painting a kids pedal bike. a small size little air compressor most likely ok.
other words why it would be nice to have a higher CFM (cubic feet per minute) of air being created by the air compressor itself. having a small size air compressor. and more tank gallons can help relieve issue of not having a bigger air compressor from get go.
check craigslist.org for old air compressor motor / compressor does not have to work, just pull the stuff off and get a couple fittings, and use tank as extra storage when wanted / needed.
heck even menards / lowes / homedepot / grainger / harbor frieght / farm king / farm and fleet ... etc... every now and then have some pretty cheap prices. on air tanks / portable tanks.
to note it...... my requirement is small size air compressor. is to run off a 3000watt generator. meaning it is pretty much lowest handful of models most places sell as far as air compressors.
trying to drag around a 220v shop size air compressor that comes on a pallet is a no go for me.
   / Best budget spray gun setup #22
Your 5 cfm @ 90psi should work fine, as long as you don't plan on continuously spraying- take a pass, stop, take a pass, stop, so forth. You can plan on your compressor running a lot, but if it builds to, say, 135 psi, you will be fine. The HF guns work at around 50 psi, and if memory serves me, maybe about 10 cfm? which is why you can't spray without stopping until the gun is empty.r
1986 East Tri Axle Semi Dump Trailer (NO TITLE) (A50774)
1986 East Tri Axle...
Case 586H (A50120)
Case 586H (A50120)
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
