Best implement to turn grassy field into garden
   / Best implement to turn grassy field into garden #11
Got a large area I was thinking about turning into gardens for various vegetable crops. Was wondering what the easiest way of doing this as it is all currently grassy fields. I understand it's not as simple as just turning the soil and planting stuff, but more of a question of what implements would be needed. Is it as simple as getting a tiller?
I have installed new gardens in various ground conditions. From plucking rocks and removing brush and stumps on one site to expanding one garden farther into a lawn, all have turned out real good as in happy campers for customers.
If the garden is a pre-existing its a no brainer.... tiller. Till in a north-south direction first and if room permits, till cross ways east-west, or vice versa. Makes very fluffy, easy to work and shape soil
If its a new garden or sizable expansion, rip the ground first with a subsoiler, box blade, middle buster, cultivator or something that will help break the surface tension of sod, roots, settled soil then use the tiller.
Also, If you rip first it helps you find items buried that will test the slip-clutch and tine integrity of your tiller and really don't have much use in a garden such as cinder blocks, large rocks, buried vehicle parts and such.:D
It could be as simple as just getting a tiller and just till the heck out of the ground, but it will turn out better if "ripped" first in grassy or 'unknown' conditions.
   / Best implement to turn grassy field into garden #12
I would go for a good used 20-25 hp tractor and a used subsoiler and a new 48 inch forward rotation tiller. This should be done for around 5K. Ken Sweet
Why not a reverse rotation tiller? Cost?
I'm mulling the same how-to-make-a-garden issues as the original poster...
   / Best implement to turn grassy field into garden #13
Cost and if there is rock or roots it will suck into the ground and excessively slip the clutch or stall the tractor. Ken Sweet
   / Best implement to turn grassy field into garden #14
I really think all this is a overkill. how big are you going to make it? a tiller behind a tractor is really all you need. If you are going to make it 20 by 100 or smaller, then just cover up the grass area with tarp or plastic or what have you to kill grass NOW till its dry enough to till. I see you are in NH so I guess sometime in may is ideal to start tilling.
Doesnt matter how big or small you are going to make it, tilling it every 2 days for a week will give you the results you want esp. for first year to get started.Tilling it alot in a week helps it to dry out and warm up faster. You really want to till it alot the first year to prevent more then half of vegetation from growing back.
a middle buster or potatoe plow is a good way to get started to turn over the grassy area now is a good way to get it to decompose now, but if you are short on funds, get a tiller to get started.
   / Best implement to turn grassy field into garden #15
Tiller-tiller... If grass is really thick-spray with round up- till. Tiller is an awesome tool to have and after buying one I doubt that I will use the disc much this year. Granted if I was doing a 2-10 acres then I would use the disc. But with small areas the tiller is the only way to go..
AndyG
   / Best implement to turn grassy field into garden #16
Not knowing what your budget is or if you have a mule, toy, plaything to use for rediculous uses like beer runs, orange or green iron etc.
The quick and the dead answer would be an
1.BCS 2 wheel tractor from earthtools
2. a 2 way rotary plow for the BCS 2 wheel tractor
3. the smallest rototiller for the 2 wheel tractor
for cultivation if you intend to make a flat land
garden.
You may not want to bother with the rototiller
when you see how a rotary plow will dig
14 inches deep.
If you dont want a 2 wheel tractor contact Ken Sweet
here on the forum and tell him about the tractor you own
and he will sell you the right equipment.
   / Best implement to turn grassy field into garden #17
A few questions -
Are you implying my B7610 (24HP, 18PTO HP) is to small?
If I only need 2 more PTO HP couldn't I just go a little slower?
From Everything Attachments website a Phoenix T4-48 requires 15-24PTO HP.
   / Best implement to turn grassy field into garden #18
Im not sure its quite that simple, you may be right, I'm still learning but I thought that you need a certain amount of pto hp to run an attachment effectively without bogging down the engine. Like I say, I could be way off base but that was my take on it.
   / Best implement to turn grassy field into garden #19
Pay someone to till and disk it for you, then use your new tiller to maintain it.
I did the cutting, used a neighbor's tractor to break the ground, I tilled it, and used another neighbor's tiller. We share a lot around here... I wish I had a tiller instead of the disks now, but Landpride makes great discs!
   / Best implement to turn grassy field into garden #20
A few questions -
What is your lift capacity? I have a T10-35 Phoenix that weighs about 450. Pulling wont be a problem. We also sell the T4-48 for less and it would work fine on your tractor. Ken Sweet
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2022 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2022 FREIGHTLINER...
Bobcat 72" Skidloader Bucket Broom (A50775)
Bobcat 72"...
AGT Industrial MX-MRT14 (A47477)
AGT Industrial...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
