Best leveling implement
   / Best leveling implement #1
deereman10
Bronze Member
Elroy, WI
John Deere 2440
After a field has been plowed, what implement does the best job of leveling the ground and preparing the best seedbed. Disc? Springtooth? etc
   / Best leveling implement #2
Field cultivator with the rolling baskets
   / Best leveling implement #3
Disc with a heavy drag following behind. Ken Sweet
   / Best leveling implement #4
I used a disc harrow for this purpose, and once it is broken up with all the large dirt clods gone there are lots of finishing tools that can be useful. I have found that my landplane with straight blades does an excellent job of smoothing out fields and lawn areas. I assume that what you are asking is really "smoothing" not leveling. Leveling can be a whole new can of worms.
   / Best leveling implement #6
I have found that a cultipacker does really well for preparing a seed bed once the area has been disked. I haven't used one personally, but I have seen fields that have been prepared with a "do-all" and it looked GREAT.
I was also thinking about a cultipacker. Do you think you could skip this discing and just use a cultipacker?
   / Best leveling implement #8
Are you starting at primary tillage with a moldboard plow or chisel plow?
From there disk first.
Then you can run a field cultivator for a fluffy bed or a cultipacker for a firm bed. Skipping the disking will not work with either.
   / Best leveling implement #9
No. Plowing turns over soil/turf without much breakup. Disking then chops it well -- a necessary step.
larry
   / Best leveling implement #10
This looks interesting. It's made by grademaster.
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2012 John Deere 7230R (A52128)
2012 John Deere...
Pallet Fees (A50774)
John Deere 960 Culitivator (A50514)
John Deere 960...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
