Best Modifications I've Made!
   / Best Modifications I've Made! #11
Look in the mirror section of most any auto parts store, you will usually find an assortment of replacement units, most with a swivel ball mounting point.
   / Best Modifications I've Made! #12
Hello All,
Here is my best Modification to date.
I decided to do the Guglio retrofit, which is a new NAPA 182 degree T-Stat that Larry retrofits and then customizes a special gasket to fit the Chinese tractors.
I installed it, then fired it up and because it is warm outside, it came up to about 90C within 5 minutes and then I worked the tractor for the next 2 Hours, the tractor had more power than it has ever had.
The temperature in the past, even on the hottest Southern California day, never got above about 40C. I think it is using less fuel as well and has no hesitation like before.
Pictures and the entire simple procedure to follow
Thank You Larry for such a great kit, I think every Jinma owner should have one after installing my own
Rick
__________________
Jinma 304
   / Best Modifications I've Made! #13
Bob Rooks said:
Please tell me how that part works. :confused:
"A good wife can bring balance to your life".........
Larry
   / Best Modifications I've Made! #14
Larry-
I know that the picture is not of you and Esther because you both have a full set of teeth:D :D :D
Bob-
the answer is love- that's how it works and the only reason why my better half is still around -Ed
That is a great picture.
The best thing about my modifications is that I have broken the light twice and replaced it for $1 each time.
I have added a tool box and found that it is very helpful except for the fact that I need to remember to put my tools back into it.
I carry a rubber hammer for implements, it really saves the feet from kicking things on.
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
Bell B30E 30 Ton Articulated Dump Truck (A52377)
Bell B30E 30 Ton...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
