best old Cub to look for
/ best old Cub to look for #1
Undercover
i have been looking for a older cub cadet gt for a couple years now and have kinda put it off alittle bit (economy)But that said it don't hurt to look.
Besides the obvious oil leaks ect.What models have held up over time and are easier to fix for less$$$$$$.I would like to find a Cub IH but the 80's or 90's would be ok too.Thanks
-----CUB STUFF-----
04 GT3235 60" deck
07 GT1554
New SWE 930 snow thrower
08 CC500
08 CC4175
18cu.ft.steel cart
/ best old Cub to look for #2
From what I've read, the X82 series are highly regarded. Watch out for the 2 cylinder series I kohler engines, these use splash lubrication opposed to pressurized so when running on a grade its possible to starve the upper cylinder of oil. Also depends on what you want to do with it. For mowing, a hydro trans may be the way to go, and gear drive for field work. I've read the quiet line series 1000, 1200, 1400 etc. have issue with motor mounts going, which affects the drive line so watch for that. You'll get varying opinions on which trans is more reliable, so take it that both are very good and go with what suits you. I've got a 109, (hydro) circa 1973. 10 HP runs strong, and these engines are very rebuildable so even if blowing smoke, you can get parts and get another 20 years of hard use out of them. Seems I'm seeing a lot more for sale in my area so watch and be ready to jump on one you like, cause if you don't it will be gone. Good luck.
/ best old Cub to look for #3
I think you'd want to look at IHRegistry.com. There is also a book out by Ken Updike that gives the general history of the IH Cub Cadet product lineup.
Because owner abuse and maintenance factor so heavily in whether you are getting a good used machine, I think you have to look at each Cub as an individual case. As the prior poster noted, the iso mounts on the 1250-1450-1650 series are known trouble spots as are the muffler boxes on those units. The steering will probably be loose on all Cubs and need attention.
I guess the other factor is what you intend to use it for. If you just need something to cut grass, then you may not care if the tractor has a hydraulic lift and hitch adaptor. If you are going to use a rear blade, tiller or plow, you'd want the lift and adaptor.
I prefer the Cubs made before they started putting side panels, iso mounts, etc on them, but then there are those who prefer the even later models just before IH Cub was sold out in the early 1980's. I think some of the later models even had Kubota diesels on them and are highly prized if you can find one in your price range. There are conversion kits to put new engines on some of the Cubs, but you'd really have to like the tractor to spend that kind of money.
/ best old Cub to look for #4
Undercover it doesn't say where you are from, but if you're close to Indiana, I have a 109 that would make a good project tractor. I'd sell it cheap.
As for the KT17 Series I engines, they are pressure lubed, but the rod journals weren't. When you got on a hill, the journals came out of the oil and fried. The series II engines added a oil port to the rod journals to remedy the problem.
AJ
/ best old Cub to look for #5
It's a topic very subject to opinion on which old Cub is the best or cheapest or easiest to fix, etc. It really depends on what you like or think you might like. Every model had it's ups and downs. I know guys (and gals) who are only in to the Cub Cadet original models, all the way to those who only like the last IH '82' models- and then those who like them all. A lot of the early MTD Cub GT's were just carryover '82' models, and they remained about the same design until the early 1990's, so they are game to a lot of people too. Remember MTD has successfully carried the Cub Cadet name now longer than IH did.
I like all the wide frame models. My favorites are the IH built 1250, 1450, 1650, then the 682, 782 and 982 hydros. They have their quirks such as the mentioned engine mount wear on the single cylinder models and the infamous Kohler KT17 S1 on the 682/782, but overall they are very robust little tractors, that when in good shape or put back in good shape are amazing machines. You just need to decide which one you want to run with and go for it- you really can't go wrong with any of the Cub Cadet GT's.
-Fordlords-
I wouldn't use this older Cub all that much.If it came with a deck and was in good shape i would mow a little with it just for fun and the same goes for if it had a blade.I would mostly only use it to pull a tow sprayer and that would be just so i could have a job for the tractor.I have two newer CC that would do the mowing.I just want it to maybe restore one day. if i find aGT in great shape i would work it harder.Thanks
One more thing i heard the 149 is a good one to get?
/ best old Cub to look for #7
I think some like the 149 series because it was the most refined wide frame series before they started making the 1250-1450-1650. The 12 and 14 motors are basically the same engine except for the bore. So folks like the parts interchange, too. The 16 hp is a different critter.
/ best old Cub to look for #8
I'm partial to the Super Garden Tractors. Those would be the 982, 1872, 2072, 1882, 2082 and a few others.
They have a longer wheelbase/frame, bigger tires and as a result more seat and legspace. I currently have 2 1872's they are around a 1990 vintage, use the Kohler Magnum 18HP twin. A pretty reliable, but not terribly fuel efficient engine. Mine has the 60 deck and the 45" snowblower.
Curt
/ best old Cub to look for #9
My favorites, and I have owned most series other than whats called a Quiet Line model, are the x82 series and the mentioned 149. The 149 was about the best of the models before they started putting side panels and quieter exhausts on them. It had lights, hyd lift and hydrostatic transmission as standard equipment. It can have the rear implment lift for rear blades, moldboard plows, rototillers ect. The Quiet Lines, ie 1250/11450/1650 ect had side panels and the motor was mounted on rubber ISO mounts to help with vibration, commonly these mounts are shot and need replaced, if not replaced the excessive vibration tears up the drive shaft joints ect. When IH went to the x82 series, the frame was modified to handle the opposed twin cylinder engines and they were ridged mounted on the frame, no iso mounts. The 482 and 582 special have a peerless transmission and belt drive, not a true cub cadet to many, the 582 was a gear drive, IH cub 3spd rear end, the 682 was hydrostat drive but manual lift, 782 is a 149 on roids, Kohler KT17 twin, hyd lift and hydrostatic trans, The 982 was the first super garden tractor, longer frame, bigger tires and a Onan 19.9hp twin. During the years of the red cubs, IH sold cub to CCC or Cub Cadet Corp, which was a division of MTD. The last 2 years of the red models, the Diesel powered 782d and yellow/white version 882 came about. They are the best of the x82 series with a very fuel effectient Kubota 3 cylinder liquid cooled diesel engine, hydrostatic transmission, duel hyd lift ablites with front ports for the power angle snow blade and a rear catagory 0 3pt hitch option. This is what I have. The red cubs ended, but the basic x82 design stayed around for many years but with 4 digit numbers like 1811, 1512 diesel ect. Definaltly check out the ihregistry.com website, many cubs for sale on there as well. Cheers Mike
/ best old Cub to look for #10
I have to agree with botamike and Ohioguy. For sheer versatility and durability, I would recommend a super garden tractor, with a diesel. I've been inside a super's tranny, it's built to last. The kubota diesel is a strong little beast that you can always get parts for. It's already been mentioned how you can have hydraulic ports in the front, a rear PTO and 3-pt, and more.
My first Cub was a 1772 with the diesel. An absolute beast that I never had a problem with. I traded up for a 1782, which I liked better because of the look, and the fender flares.....I can't remember how many times cussing because of getting mudded up by spinning tires on the 1772. I had it outfitted with the 3-pt, rear PTO, front hydraulics, and a kwik-way loader. It performed way above it's expected performance, as I had a bottom plow, disc harrow, tiller, front blade, etc. I've since owned a GT 3200, and I feel the SGT's were superior machines. I ended up selling the machine, only to step up to a Cub compact with 4wd, but often wonder if I should have kept my 1782....I loved it! Just saw a 1772 on Ebay with a few attachments.... good luck in your quest!
Thanks for all the great information alot to think about.I really like the Super GT's.Not sure when i will find one?I don't see many for sale around here that goes for all CC and when you do they are over priced imo.I don't ever see any older ones at my dealer either.Even if they did get one it would be way over priced. they have been great and i do all my buisness with them.But their used stuff is pretty high.I also check craigslist every 3 days or so.Not sure now is a great time to buy something i don't need.
Thanks again ps i live in iowa
/ best old Cub to look for #12
It sounds to me like you are trying to keep the price (and repairs!) down. SGT's are great but they tend to hold their value, for one in good shape you'll have to pay the price, especially for a diesel. The turning radius is also a bit wider on a SGT as compared to the same vintage in a regular garden tractor version.
So your intended use will be a bit of mowing, maybe a blade (I'm assuming snow?), and towing a sprayer. For great value I'd go with a 129 or 149, there are a lot of them around, sell fairly cheap, and easy to work on. That would be my choice, hope this helps!
David
/ best old Cub to look for #13
What is your price range for what you are looking for?
David
Hi Dave i got off the track with the SGT's if i fond a great deal i would pull the trigger.But that said i don't see it in the near future.
I agree with your advise on the 129 or 149's.In fact i called a guy tonight that has 2, one for $600 and one for $700.(Same guy i made a thread about "122 cub worth it").1 of the 149 has a rebuilt engine.Has a 1250 (talked about in other thread) i asked about the rubber engine mounts he said they were good and he goes throw all the stuff he sell.He also has a 1862 for sale $2200.
He says the 149's are in good shape.Its a hr or better trip to take a look do you think its worth a look for that $$$.
Thanks Dave ps i was getting advise from you last year when i was looking for a Cub GT and that worked out great thanks again.(04 3235 60"deck 49 hours at the time $2500)
I was hoping to stay under $500, but that maybe hard to do?But i'm no hurry and i can wait for a great deal.The economy is not good and this may not be a great time for this but if i find what a like i may go for it?
/ best old Cub to look for #16
The guy you are speaking to about the 149's, 1250, 1862 - When he says the 1250 iso mounts are "good" it makes me wonder if you can trust him. Are they good because he replaced them, or are they good because he says so? I haven't owned one, but from my reading it sounds like pretty much all the Quietline series needs those mounts replaced, someone else chime in if I'm wrong.
$600 to $700 for a 149 is OK, but it has to be in excellent working order with a good mower deck for it to be worth that, bring it home, turn the key and go. Any amount of rust, controls out of adjustment, very loose steering, etc. and I'd keep looking.
I think I remember the posts about the other tractor last year, I haven't been on this site in quite a while so funny you are looking again.
/ best old Cub to look for #17
Unless the iso mounts were replaced new (not used) in the last year or so, I would be automatically suspicious. BTW, there is an engine rail modification that can be done to add a cross bar stiffener to extend the life of the iso mounts. Also, they can be replaced with steel mounts if you're willing to put up with some vibration.
If I saw a 149 and a 1450 in the same mechanical condition for the same price, I'd pick the 149 to never have to fool with those iso mounts, the side panels, and the muffler boxes on the 1450 series.
We don't have too many of the Cub super garden tractors around here. Seems like Cub Cadet took the market down that path and then Kubota came along and grabbed the market with the B5200/B6200/B7200....
/ best old Cub to look for #18
All this talk about old Cubs makes me want to find one, don't get me wrong, I like my 2542 and Sc2400 but one can never have too many toys! (I miss my old Cub 86) I agree with 2manyrocks and would also rather have the 149 over the 1450...although if it were me I'd look for the more rare 169. If I could find a decent 169 it will probably end up in my garage...just don't tell my wife.
/ best old Cub to look for #19
I think I remember the posts about the other tractor last year, I haven't been on this site in quite a while so funny you are looking again.[/QUOte
NAPA has front end bushings that are even better than OEM. Work great for ISO mounts. A lot cheaper too..
/ best old Cub to look for #20
Having owned and repaired CC's for close to thirty years it is MHO that one should steer clear of hydros. Get a stick shift. They are almost indestructible. I am currently down to a 1200, 1250 and a 1960 original in addition to the 2542.
I wish I knew how many cubic yards of dirt the Original pushed for me over the years. I moved the dirt blade to the 1250 this last week. It is a tad harder working the implement lever and hydro lever at the same time. May have to move it to the 1200..
Anyway you can't beat old iron CC's. The Kohlers are cheap to rebuild using Stens parts. I have used them since they came out and they are great quality parts.
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2005 CATERPILLAR 420D BACKHOE (A60429)
2005 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
