Best PHD for CUT?
   / Best PHD for CUT? #11
Scottrh, which ETA PHD did you choose for your JD2520?
I also have a JD2520 and was already to buy the TSC/Speeco until I read about your plight and others on another thread. Since then I've been looking at the ETAs but they have so many models I'm not sure which would be the best fit? I'm leaning toward the 6900HD so that I could use an 18" auger if I wanted too and it is also a bit more rugged.
If I could roll the clock back to when I choose my JD2520 I would probably have made a different decision and either stepped up to the 3000 series or bought the Ford or Massey. The 2520 is very sturdy but they tried so hard to put big tractor features on a small tractor that they created a few problems, starting with that you need a quick hitch to use a brushhog otherwise the front of the brush hog rubs on the rear tires. You can't put chains on the front tires at all because of lack of cleareance with the steering linkage and you must turn your tire rims inside out to gain enough clearance to mount chains on the rear. The original hitch arms rubbed on the rear tires until they came out with redesigned arm in 2009. Now I find out that some post hole diggers like the Speeco Heavy Duty or the TSC won't work because of lack of clearance with the top link and ROPS mount. And to think I bought a John Deere so that I wouldn't have problems like that. I might as well have bought a NorCo or a Mahindra???
   / Best PHD for CUT? #12
As always I've done a lot of research.
Agri-supply has had the best bang for the buck for new IF you are near enough to pick it up.
Sweet and Everything Attachments are good alternatives.
Craigs list seems to have lots of "hardly used" but totally rusted out units.
   / Best PHD for CUT? #13
Leinbach is in East Bend, NC just outside of Winston-Salem. I bought one of their 7300 models last year. Nice unit.
   / Best PHD for CUT? #14
I picked up a Leinbach L-7200 unit at the local equipment auction last week. Nice unit. It is a used one and still works great. I looked at the ETA video and the PHD lineup. I Believe that the ETA PHD is a rebadged Leinbach. But I could be wrong too. At the moment it is leaning against an old trailer. I plan on sinking posts and bolting a crosspiece on it and hang it with a chain. Just trying to figure out the dimensions to use.
Good luck
   / Best PHD for CUT? #15
Kioti Tom you are correct in fact if you go to Leibachs website and click on "How to Buy" their link redirects you to the Everthing Attachments website. I think they are the same company. ETA also has free shipping. from NC to VT or anywhere within 1000 miles.
2016 UTILITY VS2RAP 53FT REEFER TRAILER (A54607)
2016 UTILITY...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
