Best quick change system?
   / Best quick change system? #11
offcamber said:
Sorry if this is an obvious question but what purpose does the stabilizer bar serve on the Pat's system?
It keeps the lower arms spread so that the arms are already the width of the pins. Many, like me, have already got lock pins built into our 3pt lower arms that will keep them spread, so the bar on Pat's is not necessary.
Only if your lower arms swing freely all the time will you get some use out of Pat's bar on the system.
   / Best quick change system? #12
I bought Carters EZ hitch, I have to swap out a good bit and I liked the idea of not adding any length to the arms, seems all have advantages and disadvantages but for my use, Carters design was the best choice
   / Best quick change system? #13
jpm1 said:
Question !
n
Where did you get the part on your quick hitch that replaces the J hook.? I have one of those and its a piece of scrap without it. John
Call their customer service and ask for Item #29309, Description "93691 Hitch Adapter, it should be in your instruction manual that came with the QH.:D
   / Best quick change system? #14
I also have the Speeco QH. I have adapted each of my implements to the Quick hitch. It is not too much work usually, to adapt each one. Sometimes you have to drill a new top hole, usually have to cut a pc of bushing, etc. The one implement that was tough was the Tiller, 'cause there were frame geometry roadblocks. It works now, but required some eccentric bushings, welded to the lower pins.
One nice advantage to using the quick hitch, instead of any of the quick setups that do not tie the arms together: You never have to screw around with the turnbuckles that hold the arms from side-sway. Once set with the arms attached into the quick hitch frame, and turnbuckles tightened and pinned, you simply hook stuff up.
When I look at the pics in this thread showing the Harbor Fright QH, I can see it is IDENTICAL to the Speeco product.
I modified my Speeco several times. After the best height for the top hook was determined by a quick survey of my then-existing attachments, I cut off all the "extra" height of that holed bracket that is welded to the top of the QH frame. Otherwise, it interfered with my hydraulic hoses. Also, just lately I added a new channel, of 2x3 angle iron, to the inside surface, each side, to form a new pocket for the tractor arms to connect to. Of course I drilled the hole clear thru the new steel part too, and use longer pins. Doing this gave me 1.5 inches more clearance between each 3-pt lower arm and the inside of the tire. I still need to get some pics of this for you guys.
   / Best quick change system? #15
Jim, The first modification that I made was to get rid of the crappy turnbuckles and switch to the telescoping links, sure a lot easier to pull and replace a pin than it is to mess with the turnbuckles and a wrench. That was before I found the Pats and they are still one of the best mods that I have made.
2343 (A58376)
2343 (A58376)
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
