.???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #11
You could also put a couple of self tapping screws thru the joint to hold the pipe into the metal socket. If I were welding it, I would use 7018 electrodes.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #12
I guess to confuse even further, I'd vote for 309 or 312 Stainless or Silicon Bronze Mig or Stick.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #13
309/312 would have been my suggestion too.
How are they "supposed" to be assembled? most of the handrail fittings I have used have a large set screw and not designed to be welded. If they ARE designed to be a welded fitting, as the MFG for the proper process.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #14
Have you asked King architectural metals?
For welding steel to cast iron for decorative work they recommend 6011. It works. Not sure if malleable is kin enough to cast for it to work or not, but the carbon in the flux seems to work pretty decent for gluing those two together. It doesn't crack as readily as other rods. 7018 will crack at the root when it cools.
If not, I'd braze it...
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #15
Google "Kee Klamp pipe rail fittings" it might save you a lot of grief.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #16
Similar but this is what we always use at work McMaster-Carr
Not sure what other type of fittings there are, but if it dont have a set screw I would assume it is "supposed" to be welded?????
Really would like to know exactaly what the fittings are and what the mfg says
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
20701 (A55853)
20701 (A55853)
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
