best size baler
   / best size baler #1
redipsweb
Springfield, TN
Kioti DK35se 4x4 (sold), DK45se 4x4 (traded), NX5510 cab
What would be the best round baler to get for my tractor (38hp, PTO 28hp) that would work?
   / best size baler #2
You would have to look at a Micro-baler like a Star. Your tractor is not big enough even for the smallest 39" x 48" AGCO baler that needs 35 Pto HP.
   / best size baler #3
Your cheapest option is to buy a nice used 60+ pto hp tractor for $5500 and a then get a real round baler.
Those micro round balers that fit your tractor are too expensive, and make a tiny round bale that is kinda awkward to handle - too big to manhandle, too small to use regular hay tools with and no savings on twine....
--->Paul
   / best size baler #4
With the size of tractor you want to bale with you will end up with bales around 100-250lbs. The bales would probably look like and be the size of the ones that the early round balers made.
   / best size baler #5
I have a 33 hp 26 pto hp mahindra. Last year i bought a 605 c vermeer round baler. I made over 75 5 foot round bales with it. No bs. It wasn't fast baling and i had to let her cool down often but i did it. It a difficult baler to use but fairly common. You can adjust the size of bale by tying anytime you want. I also hauled them off 2 at a time. One on the back spear and one up front. Could load a 3-4 foot high trailer no problem. The bales are just the right size to handle with a smaller tractor.A rear bale spear is nessacary though or else the tractors *** will lift when you try to move the bales..People thought my small tractor was a bad investment but my sheep ate well all winter at a lower fuel cost.
   / best size baler #6
id step up to a 50 to 70hp tractor an then you could pull a 4 by 5 or 4 by 6 baler.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
1837 (A51248)
1837 (A51248)
Case 721C Wheel Loader (RIDE AND DRIVE) (A50775)
Case 721C Wheel...
2015 Ford F-450 (A53314)
2015 Ford F-450...
CFG Industrial MH12RX (A53316)
CFG Industrial...
weber crs plate compactor (A55787)
weber crs plate...
