KeithInSpace
Veteran Member
I deployed a fairly heavy seed and starter fertilizer load simultaneously in October '07 onto the raw earth. I covered with hay and watered it 3 or 4 times a day (to keep the seed wet) for about 2 weeks, then cut back to 2 times a day, then once, then every other day when it was going good. I didn't touch it the following spring. It actually stayed quite green through the winter because of the starter fertilizer. The "good" picture was from Spring '08 after the first mow of the season. No pre-emergent in '08. No straight fertilizer either. Probably should have done the pre-emergent.
I did get some weeds popping up mid-summer and I hit it reactively with Scotts weed/feed. The lawn was very well established before I did this. I did the same thing in the fall with no additional care. Should have aerated/dethatched.
By the fall, it was starting to thin a bit under the trees, especially where I turn sharp around trees. Some of the fine rye thatch was starting to choke out the better grass. This probably could have been remedied by an overseed/fertilize this past October, but money has been a little funny.
I'm back on track this year and it's greening up a bit. Still has some thin spots, but I'm going to spot-seed between pre-emergent treatments (I'm hitting again in May). That should be it until the fall when I'm doing some patchwork, overseed, and fertilize.
Hope that answers your question.
