Best way to remove/reuse t-posts?
   / Best way to remove/reuse t-posts? #11
The way we have always done it is to take a chain, attach it to the FEL and then have a helper walk by and wrap the chain around the post. The only thing is to be careful and wrap the chain low enough down the post. The reason for this is because there is a possibility that the chain might slide a little before it catches on the post. I know people are worried about bending the posts but I am fairly certain that if you lift straight up instead of at an angle you should be fine.
On the driving post side of things....the best way I have encountered is to have someone hold the post and the other person to slowly lower the FEL onto the post. This works rather well but just be careful not to set the FEL on your helpers head! But in all seriousness this way works rather well. I mean I wouldn't want to pound 5000 ft of fence posts by hand. would you?
I don't have near that much to do, but I still want to use the tractor as much as possible. That's why I have it.:)
I bolted 3 hooks onto my bucket a couple of days ago. There seems to always be something I am needing to pick up that I can't just scoop and go with, so I put 3 10k lb hooks on the backside of my bucket.
   / Best way to remove/reuse t-posts? #13
If you have two people a FEL and piece of chain are quick and easy.
Years ago I built a puller for dad.
As far as using a FEL for driving. If its not to rocky and you have a helper it can be done. I like the old fashioned post driver.
   / Best way to remove/reuse t-posts? #14
66 posts a day, with range wire, straight, all within 1".:) Only 4700' more to go. 6000' total to complete, all posts driven by hand.
   / Best way to remove/reuse t-posts? #15
I guess you won't need to be going to the gym! I’ve set 120 in one day, but that was with a pneumatic t-post driver and a tow behind air compressor. The driver weighed 55 pounds so I was still pretty worn out. I have to pre-drill with a rock drill for most of my t-post. Looks like you have sandy soil to work with. Still, 66 a day is impressive.
   / Best way to remove/reuse t-posts? #16
The 66 posts are no problem, if that was all I was going to do. But to stretch and install the range fencing makes for long days. No rock for me, either topsoil or decomposed granite.:)
To actually have to drill for each post:eek:, now that is a lot of hard work no matter how you do it.
   / Best way to remove/reuse t-posts? #17
I have removed t posts using the FEL. I have a about a two foot length of chain with clevis grab hooks at each end. One clevis is hooked on the blade part of the bucket, centered in the middle of the bucket. Wrap the chain a time and a half around the t post and yank it out. I haven't bent the bucket doing this yet, but it is probably possible someday. I don't have a welder to put a ring or clevis hook on. I just bought one clevis hook that would fit snug over the bucket edge.
I also use this method to pick up my three point hitch attachments and move them around.
Just a warning, do this slowly, or your in for some interesting and unnerving tractor reactions.
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
1989 CATERPILLAR 963 CRAWLER LOADER (A52707)
1989 CATERPILLAR...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2019 Nissan Titan Crew Cab Pickup Truck (A55852)
2019 Nissan Titan...
