Best way to Vent storage tank?
   / Best way to Vent storage tank? #21
Duh!! I guess it does say it's vented. I must be getting old timers. It must take slot of pressure to vent. After being in the sun it almost blew cap outta my hand into the air.
Ummmm... Never mind.
Thanks for all the suggestions though.
I would guess it works like the fuel caps on vehicles, air can go in, but not out.
   / Best way to Vent storage tank? #22
My 50 Gal transfer tank came with a fill cap that has a spring loaded vent built into it. It maintains a positive pressure in the tank but opens to let air in when pumping fuel out. I never have had a condensation problem here in the wet Puget Sound region. No rust in the tank and no water build up. The positive pressure feature must work. Check this out:Cim-Tek Vapor Control Fill Caps (2" NPT) - Non-Locking Base and Cap - 60001
Ron
   / Best way to Vent storage tank? #23
Do it right buy the Prevent cap. A fuel tank should hold a little pressure inside. a small amount of pressure in a hot tank will seem like a lot.
Apparently it came with vent cap. I didn't realize how much pressure it built up before venting. It works great. Each stroke is 1/2 gal.
Sent from the mountains
1983 Case 580D (A47477)
1983 Case 580D...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2012 John Deere 850K Crawler Tractor Dozer (A52377)
2012 John Deere...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
