Best Way to Weld Aluminum
   / Best Way to Weld Aluminum #21
Do you just swap liners when going from steel to aluminum? Never really thought about how much time/effort it would take to convert the same machine back and forth:
1. Swap gas bottle (same regulator?)
2. Remove standard wire spool.
3. Swap out liner & tip
4. Install Al wire
5. Reverse for next job on steel
Anything else?
I have a separate whip for aluminum. It is much faster to swap whips. So, I swap whips, wire, and gas bottle.
Eric
   / Best Way to Weld Aluminum #22
Eric
Same regulator? Never checked fitting compatibility between C25 and pure argon bottles. Or do you just run pure argon for everything?
   / Best Way to Weld Aluminum #23
Same regulator for C25 and Argon. Different reg for CO2. For MIG welding mild steel C25 is much better than pure argon.
Eric
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2018 Ram 3500 Reading Service Truck with Liftgate (A50323)
2018 Ram 3500...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
