Best Zero Turn for my property
   / Best Zero Turn for my property #21
My Ferris has a 25hp air cooled kawi and I can pretty much bush hog with it. If you are cutting something that you keep mowed then 25hp should be more than enough...
However, with that said, more power, usually, is better....
I will tell you, the 25hp kawi sips the fuel. I'm very impressed how little fuel it uses....
   / Best Zero Turn for my property #22
Scag makes a 3 wheeler, rear steer, front wheel drive unit. I think current model is: 61"STHM. Not cheap. I own 2 much older of this model and a large dam to mow. One is 28 years old and has had 1 engine replacement , several belts , and 1 spindle replaced. the other is newer (lol) only 19 years old , same engine Kohler 18hp, about the same repairs. These are rock solid. Front wheel drive pulls you up the grade and with engine and deck in front gives confidence going up of not turning over.
KUBOTA M8540D TRACTOR (A60430)
KUBOTA M8540D...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2018 Kia Soul SUV (A59231)
2018 Kia Soul SUV...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
