OP
Outlawmoon
Eric - I looked at the pic of your backhoe again...are you still using the standard bolt teeth on that bucket?
I kept breaking mine so I bought a second bucket and had a second cutting edge welded on to the front (making that edge of the bucket thicker) and then 'frog's welded on to that and then was able to use $8 teeth tap on teeth instead of $40 teeth..... Since I did that I have not replaced a tooth on that bucket - go figure!!
The newer buckets also have weaker back ends to the buckets so you may have to have the pivot pin ears cut off, weld on so 5/16 to 3/8's inch steel over that area and then weld the ears back on.... That's what I did. It made that bucket heavy but indestructible! or you can weld 5/16 to 3//8's inch steel right up on to the ears on the bucket.... Either way should keep the curl force from wrecking your bucket.
Just a thought...
Just a thought...
