Big Cars are killing Americans
   / Big Cars are killing Americans #521
My dad used to say that he couldn't drive with the radio on as it distracted him. So as Dirty Harry said you've got to know your limitations. Everybody has different limitations.
I won't argue with that as I don't like being wrong. ;)
   / Big Cars are killing Americans #522
Yeah. I’ve never seen so many axles on a trailer as I’ve seen in Michigan. How do they turn a corner?
Very carefully actually. On an 11 axle rig (8 on the trailer 3 on the tractor, on the trailer most times only a tight 4 axles are on springs and the rest are on air with the ability to lift prior to going around a corner. Sometimes, they are all on air and you can choose in the tractor cab which ones you want to lift. The one I ran had 4 tight on air the two in the back lifted and the one in the front (which was spaced out at 10'2" from the centerline of the first stationary axle lifted too). Trailer was a 48 foot aluminum with a curtainside on it. One time I forgot to lift my axles when making a turn and the trailer reminded me real quick as it stalled the engine, the 3406 Cat dies in the intersection. Was embarrasing and then I tied up the intersection because they don't lift instantly. Takes about 15 seconds for them to begin to lift.
Michigan also has a law about lift axles and that is, once you lift them and make a corner, they have to be back on the ground (and tires rolling) within 300 feet of the corner and Michigan cops watch that real close. You go past the 300 feet and get pulled over, they will take you back to 80K gross on the portables and when you are loaded with 100 plus on the deck, the fine is astronomical.
With a Michigan Special (Sled), there is a whole lot more than just shifting gears.
With the axles on air, you have to know how much down pressure is equal to how much weight too. Had a whole row of gauges in the cab that told me how much down pressure was on each axle and I had to calculate in my head what that pressure was equal to in weight carried.
You have to know exactly how much weight each axle is carrying when you cross the scales. There are very strict rules that apply to axle loadings in Michigan. Used to run in your state as well. I could run in Indiana on certain routes with heavy haul permits at the same weight as I was tagged for in Michigan. Used to go to Indiana Harbor and Gary and pick up master coils and haul them back to North Toledo and Detroit. Usually a couple 40's but sometimes 5 20's. Loaded out of Butler, Indiana at SDI a lot too, as well as our plant which sits right next to SDI. One of the guys I hunt with is the current plant manager there.
Takes big power under the hood too. No weenie motors allowed. We always ran big Cats with 13 or 18 speed Roadrangers. Takes some serious horsepower and toque to get 160 thousand plus rolling and a lot of braking power to stop it too. Most of the Cats were turned up to the maximum allowable factory power and some were cranked past that, way past that actually.
Really dicey times are during periods of wet weather and snow-icy roads. Had many times of sweaty hands on the steering wheel knowing what was behind me. Nice thing about them is, with all the axles down, loaded they tended to go straight no matter how slippery the road was.
Retirement is nice but I do miss it sometimes.
Hope that explains how they work.
   / Big Cars are killing Americans #523
This seems to fit into this discussion.
Throughout the article it's tough to be sure what happened or who was at fault. He was northbound, they were southbound... were they crowding the centerline as motorcyclists are prone to do? Yet at the end they state that the SUV driver was "arrested on two counts of Operating While Intoxicated Causing Death."
Edit; another article states that he was trying to pass another car. Car strikes cyclists in mid-Michigan, killing 2 and injuring 3
   / Big Cars are killing Americans #525
   / Big Cars are killing Americans #527
The irony is that had she stopped, there shouldn't have been a problem. Granted as a bicyclist he feels that he has special privileges. Yet even a pedestrian crossing against the lights as he was can be charged with Jaywalking...
I have almost hit a few cyclists that run the stop signs at a particular intersection on the north side of town. Thay are riding on a paved trail for pedestrians and cyclists that crosses a busy intersection, and has stop signs specifically posted for trail traffic. They usually just buzz through the intersection in their fancy (and expensive) shorts, tops and wierd helmets, on their $5,000 carbon fiber bikes, like they a leading the Tour de France, without so much as a look at auto traffic. I'm surprised someone hasn't been killed there. Yet.
   / Big Cars are killing Americans #528
Very well. Thanks! (y)
One thing I do caution people about and that is, when passing ANY big truck on the highway, don't diddle around. Get it done as quickly as possible. reason being is, the tires on a big truck are usually inflated to at least 100 psi and on the slim chance that one blows out as you are passing or tosses a tread (recap), it will destroy your vehicle and you instantly. Those 'alligators' you see on the roadside weigh a lot, sometimes over 100 pounds and you don't want to get hit with one at 70 mph. I guarantee bad thing will happen.
   / Big Cars are killing Americans #529
Yeah, we had one blow out right after we passed one a few years ago. BOOM! I looked in my left side view mirror and saw pieces shoot across the space I had just occupied moments earlier. That’s the only one I witnessed in my years of driving. I’d heard about it many times.
   / Big Cars are killing Americans #530
Never pace a semi bumper to bumper. Even with their fender mirrors you risk being in a blind spot when hovering alongside the cab and below line of sight. You may then not see their blinker and can be run off the road when they change lanes or dodge a lane-weaver in a sporty car, chit box, or SUV.
As a rail-fan I recognize how momentum makes sudden stopping or veering a risk to others on the road. Don't drive with packs in a hurry to get somewhere. Drive between their cluster-crunches. You'll still get there and truckers are on the job. Common courtesy says give them room to work, and don't be an accident waiting to happen when others may not.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2020 KUBOTA RTV...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
