Big Cat Concrete mixer
   / Big Cat Concrete mixer #1
Nat
Platinum Member
Central NC
I guess this is a good place to vent.
I bought a Big cat Mixer to mix small batches of mortar mix/ concrete. It has a 1/3 hp electric motor and a worn drive. I bought it at an estate sale and it had never been used, it cost me 95.00 which I thought was pretty reasonable. I took it home and used it a couple times, maybe mixed 1/2 yard total and the spiral gear gave out. I should mention the gear is plastic. Without this plastic gear it is usless and on thier website they sell new ones for 46.00 which would be bad enough, without me thinking it will give out after a couple uses. It really ticks me off when a company can make and sell such sorry stuff and we are at their mercy. TRhey know the machine is worthless without it and it probably cost them 50 cent to have it made, but they want me to give 46.00 for it.
I guess I'll take the cheapo motor off to use for something else and throw the rest away.
Sorry for the rant. later, Nat
Red Lion Big Cat Portable Electric Concrete Cement Mixer
   / Big Cat Concrete mixer #3
I surely understand your rant, but as has always been the rule of the land, "Caviat Emptor".
It costs quite a bit to develop and produce custom parts. A lot of time these designs draw from commercially available products to keep production costs down so they are able to produce and sell a cheap product and stay in business. It might also be that the person who designed it, didn't apply the correct stress criteria to the application of that part. I have a bit of experience with nylon/plastic gears and worm drives in RADAR systems. I have only seen one really fail and that was because something fell and hit/stopped the array and broke/strippd the gear. In a properly designed application, they last for years.
Kinda funny that part is listed right up front on the same page as the whole mixer, you don't even have to search for it in a parts listing. They made it real easy to find cause you are gonna need it...
It may be that that worm drive is available thru other sources, you will just have to determine the exact specifications for it so you know what to look/ask for. A company such as Stock Drive Products Mechanical Components, Timing Pulleys, Gears, Clutches, shafts, sprockets, Bearings, Brakes may have what you are looking for.
Remember it is not broken till YOU can't make parts for it...
Good Luck
   / Big Cat Concrete mixer #4
Nat, take the old one to a reputable machine shop with a CNC lathe, or VMC (vertical machining center). A good programmer can knock that out in short order. Have one machined out of 6061 T351 Aluminum. Maybe a little more than $46, but it won't break, or wear out. :cool:
   / Big Cat Concrete mixer #5
I would think if one is wore out, the other mating gear is probably worn also, change them together,
Jim
   / Big Cat Concrete mixer #6
Like IH3444 said take it to a good machine shop and have one made, but I'd use Delrin. I've made bushings for race cars out of it for years, it"s self lubricating and never seems to wear out
   / Big Cat Concrete mixer #7
I also made bearings out of Delrin for one of my Hay Wagons and it has worked great for the last 8 years.
Jim, I told Vickie last nite that I was going to throw it away, but now you got me to thinking!
BTW anyone want a Big Cat Mixer, nice but needs a little something? later, Nat
   / Big Cat Concrete mixer #10
and now it's up to $55, anyone come up with a work around?
Mine lasted about 200 bags.
2018 Ford F-450 XL Super Duty (A44501)
2018 Ford F-450 XL...
2008 Ford Crown Victoria Sedan (A44572)
2008 Ford Crown...
2017 INTERNATIONAL LF687 (A45046)
2017 INTERNATIONAL...
2022 Kingsport 248BH 26Ft. T/A Travel Trailer (A44572)
2022 Kingsport...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A44571)
2023 Caterpillar...
SB-35 Hammer (A42203)
