Big Diesel, 110,000 hp
   / Big Diesel, 110,000 hp #1
JJT
Upstate NY, USA
Kubota L3710 HST and a Kubota ZD21 60Pro
I tripped across this 2 stroke diesel engine:
web page
only 14 cyl, but 110K hp
   / Big Diesel, 110,000 hp #2
That's big! you would want a big tractor to put that in or maybe i could put it in my houseboat /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Big Diesel, 110,000 hp #3
More power!!!!!!! I want more power!!!!!!!!!! /forums/images/graemlins/grin.gif G
   / Big Diesel, 110,000 hp #5
Tripped? Lucky you weren't killed! /forums/images/graemlins/cool.gif
That's a big engine.
Those things
run forever, too.
Some years ago, I was in South America on w water project. The main pump station for Paramaribo was four old Swan diesels made in the 30s. They were small, only 4 cylinders and stood about 10 feet high. Impressive machines, with 1/2 inch pipe oil lines and a catwalk around the valve covers. Old tugboat engines, I was told.
I'm sure they're still thumping away today.
   / Big Diesel, 110,000 hp #7
I wonder if Henro could translate those signs on the wall. My guess is: "And the Americans always say we build it smaller and cheaper..."
   / Big Diesel, 110,000 hp #8
In the 1980's, I performed a 2 week Naval Reserve Exercise aboard a Danish Built Merchant ship which had a 7 cylinder 35,000 hp Fiat built Diesel. It ran at 95 RPM Maximum and idled at 35 RPM. To Back the ship down, there was no clutch material that would hold up so the process was to stop the engine and reverse the engine itself. It ran as well in either direction. It would start on Diesel and warm up then would be shifted to Bunker "C" fuel which was nearly crude oil. It had to be shifted back to diesel and run at full power for 2 - 4 hours before bringing it to port and shutting it down. Everything wa computerized. The Aluminum pistons weighted 2,500 lbs and you could stand in the cylinders. The crankcase had huge hinged doors to access the lower end. Quite impressive and it worked well for a point to point vessel. You could disconnect a cylinder and run on 6 or 30,000 HP. I'm sure there are bigger one out there. This ship was around 35,000 tons gross registered tonnage and 650' long. It was part of the Maritime Prepositioning Force in Diego Garcia, an island 1,000 miles south of India.
A great experience.
2005 Ford F650 SVI Crew Cab Fire Truck (A49461)
2005 Ford F650 SVI...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
