Big enough for the job?
   / Big enough for the job? #41
I live in NH and have a BX1880 and it handled our snow just fine. I doubt anything beyond our rare and exciting "actual" blizzards in the 24"+ range and wet would give trouble. I have less HP than you are shooting and I have to actually rev mine down because it throws the snow so far it was landing on my neighbor's property.
Only downfall are the super crappy 1-3" slush storms...which suck for any snowblower. I put it in high gear and use that speed to pcik up enough slush to load the blower. I literally blew 5" of pure water/slush multiple times last year and never had it bog down.
Update:
I went to a fair today and looked at tons of tractors and haggled on prices. My final two choices are the Kioti CK 2610 and the Kubota B2650.
Kioti Pros:
Bigger frame
Heavier (might be a con)
Much more lifting capacity
Better flow rate
SB66 blower is a beast!!!! 66"
Dealer down the road
Cons:
Same price as Kubota because blower is $7500
No tilt steering
No AC
Lower resale
Blower auger is chain driven
Kubota Pros:
Higher resale
Quicker blower removal
Cab is awesome. Comes with AC, rear wiper, armrests, Kenwood stereo
Shaft driven blower
Cons:
Much lower lift capacity
Blower is not as rugged and is 63"
So I will take it all in and pull the trigger on one of these on Monday.
The outlier: JD dealer is offering me a great deal on a JD 2032R. $1,500 cheaper than the Kioti and Kubota. But has an ugly Curtis cab.
I'm open to ideas on the top two choices.
Thanks!!!
   / Big enough for the job? #44
If you're buying it to re-sell it, and want it to be less weight on your trailer when taking it to the dealer for fluid changes and tire pressure checks, buy the Kubota. It's a nice 'lightweight' CUT for it's hp.
If you''re buying it to use it, can pull your own maintenance routine, and want the size, useful weight, (traction) and FEL capacity of many 30-35 hp CUTs (eg: my two >30hp NHs) but w/o the Tier IV baloney, buy the Kioti.
The Kioti is somewhat 'more tractor' than either of my NHs. The Kubo is smaller and lighter. btw, a rule of thumb for me in this size category is 15x 19.5 R-4s on the rear or you're missing out.
You may have noticed that M-F and Branson don't offer true peers to these. IIRC Mitsu does, and competes strongly with Kioti in this size/use class. t o g
   / Big enough for the job? #45
If I was replacing anything I would go with the b2650, that is a nice tractor. Don't know or I missed in a thread where are you going to keep the tractor, I would just about bet they will not fit into a regular overhead garage door (7'). I always have to measure before I buy to ensure things clear. We keep talking about building another garage(shed) with higher opening, but I need to downsize instead of having another place to store stuff.
The B2650 is very nice. I think the cab is far superior. But Is a nice cab better than longer frame, greater lifting capacity and more weight? That is what I'm torn between. My garage doors are 11 feet tall.
   / Big enough for the job? #47
Garage is for cars, truck and bikes. Barn is for tractor(s). My barn door is 14 feet high....:D
   / Big enough for the job? #48
A B2650HDDC with factory cab is over 88 inches = 7' 4"
Obviously a rops version will go easily with it folded down.
Signed, sealed and waiting for delivery!
Pulled the trigger on a:
2019 Kioti CK2610
SB66A Blower
Cab
Loader
Turf tires
Additional valves
And some other odds and ends
Kubota B2650 is very nice but Kioti is bigger and specs out better.
So, to address my original question, I think the CK2610 is big enough for the job.
Thanks everyone. Your opinions mattered.
   / Big enough for the job? #50
Signed, sealed and waiting for delivery! ... 2019 Kioti CK2610 ... to address my original question, I think the CK2610 is big enough for the job.
I'm so proud not to be the only one to recognize what a BAMF the 'no tier IV' CK 2610 brute it is, but also jealous after seeing them in person and comparing 'SxS' to the barely equal* CUT I was there to pick up ... besting mine in everything but rated hp, so FEL & 3PH lift, std Fel cap, o'all weight: ... me not even close with my 2nd, 3rd, 4th, NH/Shibauras ... that I got seat time on (also T5C) Yesterday .. 9/30/2019. :cool:
* '04 NH TC33DA (Shibaura, 1.5L 'loaded')
What you did, IMO ... :thumbsup::dance1::drink::):dance1::) ...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2020 Ram 1500...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
1981 JOHN DEERE 570A MOTORGRADER (A52707)
1981 JOHN DEERE...
