BL25R FEL Operation Question
   / BL25R FEL Operation Question #41
If the pump is drawing air it would be noisy and affect all of the functions not just the dump.
Floppy bucket is caused by the cylinder extending faster than the pump can supply. This creates a vacuum in the cylinder which creates an air pocket. This is also called an overrunning load. Holding the control valve until cylinder is fully pressurized eliminates the vacuum and greatly reduces the floppy bucket.
Different ways to reduce or eliminate this occurrence.
Regenerative system: valve connects both the rod end and cap end of the cylinder to pressure so fluid exiting the rod end is forced into cap end pump only makes up the volume difference of the rod. Since both ends of cylinder are at similar pressure very little chance of drawing a vacuum
Orifice or restrictions in rod end hose. Works ok but requires some fine tuning to get control under most conditions. Has very limited success if trying to feather control especially with load on forks.
Counterbalance valve: these are designed to prevent overrunning loads from running away. This style valve keeps a positive pressure in the rod end of the cylinder. These Work well under all conditions but are the most expensive solution and potentially challenging to install on existing FEL circuit.
   / BL25R FEL Operation Question #42
I have also noticed when you lower the loader to the ground once making contact it takes a few seconds to start to raise the tractor. And also noticed the steering has whine to it.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
1979 LUFKIN TRAILER (A50854)
1979 LUFKIN...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
