SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,485
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
My second question is in relation to using my rear blade to plow snow. I have found that if trying to plow any snow deeper than a few inches I loose traction and the tractor "chatters/shakes" trying to regain traction. Sure don't like this feeling and seems hard on the driveline. Is this normal?
Thanks very much for any help
Merry Christmas to all!
Your engine oil darkening is normal. If cylinders and rings came already broken in in a new engine the darkening would happen slower, but alas. After the engine is broken in, soot getting to the crankcase will be slowed, but you wont notice because every oilchange the new oil will imediately rinse the inside of the engine and "look" dirty.....I should have also noted....I am running R4's...
Regarding plowing - loading rears might help. We plow with a similar sized tractor with loaded rears and a loader. It does well forward in 6" snow with 7' angled back blade. It has Ags tho, giving a bit more traction and directional control. The fronts carrying the extra weight of the loader bucket helps them pull to keep aimed right. We move along at about 6-8mph so the snow throws a bit.
larry
