Black pipe or galvanized for shop air lines?
   / Black pipe or galvanized for shop air lines? #31
lots and lots of comments.... ya know, i can pick up 100' foot extension air hose fairly cheap. as long as i put in enough pipe hangers (prefer plastic hangers with smooth edges) and account some for stretching and bowing down of the line. for slop and getting water to goto a tank or drop leg.... what is the issue?
folks are talking PEX, but there is a good amount of other hoses out there, that are rated for higher pressures, and are rated to be exposed. and not needing a protection cover over it.
to not it CPVC and PVC (solid hard plastic is a NO NO) but the softer plastic hoses should be fine. only issue with plastic, is heat/UV light and causing things to wear quicker, may eventually start to leak if you have major vibration going down through the lines and there is a sharp point / spot were hose can wear down.
some issues i have with galvinized or black pipe. is the fittings to pipe. there is a "edge" were water can get trapped at. along with other crud. before the water has a chance to flow onto the next section of pipe.
copper fittings on the other hand. generally have a much smoother adjustment all the way through fitting and to the next section of copper pipe.
various plastic hose fittings. also have ugly internal connections. though some of the more expensive PEX connections have a better internal flow to them much like copper pipe.
   / Black pipe or galvanized for shop air lines? #32
Yes, that is a purpose built product for compressed air systems, probably on par with copper when you price it out.
You mentioned "PEX" and "Kitec" so I took that as you where suggesting the regular stuff made for water lines-hence my comment to see if they approve such use.
I did Google "Kitec" though as I had never heard of that brand, all I found was reference's to a major class-action lawsuit and settlement...
   / Black pipe or galvanized for shop air lines? #33
Yes the early fitting had corrosion issues in certain conditions. Mine has the newer style fittings. The pipe I showed I would consider a pex pipe.
   / Black pipe or galvanized for shop air lines? #34
It all depends on your intended use. Some shops would get by fine with just a couple of hose connections. But other shops would not. If you have lots of different uses for air, it would be like having one 120v outlet for the whole shop, and running extension cords all over the place, and constantly having to go over and unplug one thing and plug in another. And the you end up walking/tripping over all the hoses, they get damaged by sparks and things falling on them, etc.
Long hoses also restrict air. Unless you get a really large one, if you have something that uses a lot of air like a spray gun or a grinder, their performance will not be very good with a long hose. A decent piping system will in itself act like a air tank, giving a little bit more capacity to a compressor that is marginal to begin with.
I guess this forum's theme is "do it yourself" and I include in that being able to readily buy it also at a reasonable price. Copper is nice but expensive. I think threaded pipe is pretty much the only thing you will find that has the id for good flow. Someone said something about PEX. If that would work it might be a option too.
   / Black pipe or galvanized for shop air lines? #35
from here
Best air compressor lines
PVC pipe not to be used in compressed air systems
The Department of Labor and Industries warned consumers and employers in May 1988 that plastic-polyvinyl- chloride (PVC) pipe cannot be used in compressed air piping systems without risk of explosion. By law, employers must protect their workers by avoiding the use of unapproved PVC pipe in such systems. Existing compressed air systems that use PVC piping must be completely enclosed, buried or adequately guarded according to specifications approved by a professional consulting engineer. Only Acrylonitrile-Butadiene-Styrene (ABS) piping was approved for use with compressed air, provided it was marked on the pipe as approved for compressed air supply.
In October 1989, the Plastics Pipe Institute (PPI) amended their original recommendations for thermoplastic piping in the transport of compressed air and other gases. WISHA's (Washington Industrial Safety and Health Act) Division of Consultation and Compliance Services now will accept thermoplastic compressed air piping that meets the following guidelines (recommendation B, to the PPI 1972 recommendation):
"The Plastics Pipe Institute recommends that thermoplastic piping intended for the transport of compressed air or other compressed gases be buried or encased in shatter-resistant materials, unless the piping has been manufactured from materials which shall resist shatter-type failures under the anticipated conditions. Specifically, above ground installations of thermoplastic piping should only be made using products which have been suitably evaluated and which are recommended by the manufacturer for the particular intended service.
"It is recognized that while adequacy of strength is an important element in the safety of a compressed gas piping system, consideration must also be given to the nature of failure should accidental failure occur, whatever its cause. Above-ground piping which fails by shattering can present a serious hazard to personnel by the resultant flying shards, or pipe fragments, which are rapidly propelled by the released energy of the suddenly decompressing gas. Because the inclination of a material to fail by shattering is determined not only by the nature of the material, but by pressure, pipe and fitting dimensions, and by the nature of the gas, the evaluation of shatter resistance should consider all these and any other pertinent factors."
If you have questions about the suitability of a material for air system piping, call the Department of Labor and Industries Regional Office for a free consultation.
   / Black pipe or galvanized for shop air lines? #36
Use air hoses and tees, instead of pipe, but fastened around the walls, not lying
across the floor to trip, snag, and tangle.
That's what I do, too. PVC or rubber air hoses are cheap and very easy to install on the walls and ceiling.
I am surprised more folks don't do it this way. Mine are "home-run" with no fittings, except at the 2 ends.
   / Black pipe or galvanized for shop air lines? #37
Careful of running any kind of flexible runs. Low spots gather moisture, another no go for painting.
   / Black pipe or galvanized for shop air lines? #38
Lay the hose on a 1x2 nailed to the wall, with a slope (and no sags) just like you would with pipe.
Bruce
   / Black pipe or galvanized for shop air lines? #40
This is sort of on topic, and possibly a consideration for the OP...
I work in an industrial environment, and have installed thousands of feet or black pipe for air lines. Just recently we have switched to using copper with crimp fittings for just about everything becuase it is so easy. Anyway, I have a theory about the water seperators and some agree with me and others not. Some people like to put in bigger separators (probably because they don't get emptied like they should), but I think you would lose performance that way. Looking at how they appear to work, they will do best with more air velocity going through them, so using one designed for say a 1" line on a 3/4" line would not be beneficial. Hopefully someone that knows them better will shed some light on this, and we can all benefit from the knowledge, since we are talking about moisture in lines.
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2020 KUBOTA RTV...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
