Blacksmithing
   / Blacksmithing
Polo,
I am new to this. But it can achieve welding heat no problem. I will go through my books to get specs on temperature. What you see is a flame based on 4lbs pressure out-put from a 20 lb. (BBQ) tank. From experience within our blacksmith's group some members have welded with this unit and the pressure is increased from 4 to 10-15 lbs but no higher than 15 lbs. Running at 4 lbs, generally you can run 10 to 12 hours straight. I have not tested this yet. No sure about natural gas - you have more expertise than I.
There are lots of sites on the net dealing with this type of forge and burner design:
anvilefire.com, you tube has great video of forge production, holisticforgeworks.com,
Forge and Burner Design Page #1, Building the forge
These are just a few I googled.
See my previous post #6 for PDF.
Lloyd
   / Blacksmithing #12
You would be able to the same thing with natural gas.:D
Many of the burners involved are identical except for fuel orifice size.:D
   / Blacksmithing
Polo, et al,
I just checked one of my books and forge welding occurs as follows:
Colour of metal:
red 1400f
orange 1800f
yellow 2100f
light yellow 2300f (need this temp to forge weld mild steel)
melting/sparking and burning 2400f
The image of the rod (3rd photo) shows yellow/white - 2100f+.
I guess tomorrow I will try melt/burn some steel!
Lloyd
   / Blacksmithing #14
That's true, but your not going to get that kind of pressure. He's talking 5 to 10 PSI LP instead of 3.5 inches Nat.
Usually half the pressure of propane with larger orfice, gives same BTU's
   / Blacksmithing #15
The pressure issue is what I was worried about. My natural gas is free and comes from the well at very high pressure, the pressure is reduced twice before entering any structure. If they are getting 10 to 12 hrs from a 20 lb propane tank I don't think I would with mess the natural gas. You always have to worry about leaks, especially at high pressure. I would be doing this on a very limited basis.
Mark
   / Blacksmithing #16
C3/methane - our kiln has been run on both under regulated pressures supplied via tank or from the natural gas utility. It achieved the same temperatures on either fuel. All that was changed on the kiln itself was orifice size.:D
   / Blacksmithing #17
Polo / Mark,
Love your signature line :) Kind of fits my place as well.
   / Blacksmithing #18
Polo / Mark,
My grandmother and step-grandfather owned a small fruit farm in Welland, Ontario. My grandmother (oma) was german, but my step-grandfather was 100% Polish. He didn't speak English or german very well, but whenever we asked him how the farm was doing he would say "Arbeit, arbeit, immer viele arbeit". The phrase fit him well as he was a very hardworking man. He had a couple of other choice phrases regarding birds and other pests, I don't think the moderators would appreciate those quotes.
Mark
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
Bad Boy Zero Turn **Does Not Run** (A50121)
Bad Boy Zero Turn...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
