Blade sharpening questions
   / Blade sharpening questions #1
johnnylight
upstate, New York
TC34DA
What do you guys/gals use/recommend to sharpen blades.
Where would you buy it?
I have 3 blades off my Landpride FDR 1672
am thinking grinder with built in angle adjustment.
   / Blade sharpening questions #2
I now use a Delta bench grinder, but before that my Craftsman table saw equipped with a grinding wheel did a very good job: good angle control and consistent tracking. A radial arm saw could do the job, too. As you might guess, I enjoy metal working more than wood working. Actually, the use of the saw for other metal cutting applications is very convenient.
   / Blade sharpening questions #3
I currently use a Craftsman 6" bench grinder, but I've also used a 4.5" angle grinder in the past. And for finish mower blades, if you want a really sharp blade, a sanding disk on a high speed die grinder works well, too.
   / Blade sharpening questions #4
4" or 4 1/2" angle grinder. Just follow the factory angle by watching for a full width cleaning. Grind so the wheel goes down and off the blade. Normally, you just need to touch them up a bit and that can even be done with them on the machine if you have a place to safely block it up. (Don't go gett'n squished !)
jb
   / Blade sharpening questions #5
4.5" angle grinder for me.
Wife has a commercial lawn care business so it keeps me in practice :)
I only sharpen in a vice, for me it is quicker to pull, do them right, and re-install then to try and do them under the deck.
   / Blade sharpening questions #6
i did the first time with my bench grinder, the second time with my hand held 4.5" angle grinder.
was much more pleased with the results with the angle grinder
   / Blade sharpening questions #7
I like a corded dremmel tool with a stone. Plenty of RPMs and it's easy to follow the angle. This may take a few minutes longer but I rarely have to go back and touch up because one is out of balance.
   / Blade sharpening questions #8
If they are in really bad shape I use 4.5 grinder. But usually I just use a 2" air grinder to clean them up with. But I allways finish them with a large flat file.
thanks for the replys.
I bought 3 new blades and would like to keep the others for back up.
I currently use a Milwaukee die grinder while the blades are still on.(looking for the best way)
wow what a pain in the --- taking these blades off.--Do you have any tips on a better way to get them off I used a block 4x4 then I use breaking bar with a pipe for a extender and bang she pops then I used the ratchet, my impact gun will not do it.
getting back to the right tool for the job of sharpening --is the bench grinder the only one with the built in angle feature?
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
1262 (A50490)
1262 (A50490)
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
