PineRidge
Super Member
We find it easy to remove the blades and hit them with an angle grinder. Once they are sharp a nail driven into the end of a 2 X 4 and held in the vise will suffice for the balancing job.
We do use a hand file on the backside of each blade to remove any burrs.
When you are doing the sharpening just don't bear down on the tool so hard that you overheat the blade. A damp rag can always be used in a pinch if the blade starts to get to hot.
Before balancing each blade use a stiff wire brush to knock off any dead grass or rust that has accumulated on each blade.
The blades will then cut just like new and without excessive vibration.
