Blades you cannot sharpen? BAHHH!!
   / Blades you cannot sharpen? BAHHH!! #11
I balance my blades by putting a box knife blade in a vise with the sharp side up and center the hole over the blade. Whichever side goes down I grind a bit more off till it is balanced.
   / Blades you cannot sharpen? BAHHH!! #12
Hi...
Things change...
Remember the straight razor you sharpened ?
Almost a thing of the past I'll guess...
Dave...
   / Blades you cannot sharpen? BAHHH!! #13
Sears owner's manual (model 917.272082): "NOTE: WE do not recommend sharpening blade - but if you do, be sure the blade is balanced." They go on to talk about using either a cone balancer or a 5/8" dia steel bolt or pin.
As I stated before, we got a poor cut after my son sharpened and balanced the blade. Since it is the only blade set we have had trouble with, I think the problem is with the blade and not with my son /forums/images/graemlins/smile.gif I also believe that balance should not be an issue, because of how little metal gets ground off. The manual lists only one blade for this mower. Next time, I will look into the gator blades, assuming I can get a match.
A couple of my friends all have 20HP+ Craftsman mowers and they are happy with their cutting performance. Hopefully Craftsman has changed their blade configuration -- otherwise it is certainly a point to ask about if you're shopping for a new garden tractor.
   / Blades you cannot sharpen? BAHHH!! #14
A common problem is the blade being installed inverted. Sharpen them more frequently with a file, die grinder or dremel & there will be less metal to remove, almost no heat build up to remove the temper. They will cut very well. I use the sears "wavy" mulching blades mostly, but when I'm cutting tall or slightly wet grass, I change to the high lift & remove the mulch plug. Mulching needs to be done on dry grass & should be done on a regular basis so as not needing to cut more than 1/3 of the blade to achieve the desired grass length. My lawn looks great & mulching reduces the fertilizer maintenence. Also if mulching is done with the grass even a little damp, the grass will build up under the deck & it will stay clogged untill cleaned out & the cut will look terrible.
   / Blades you cannot sharpen? BAHHH!! #15
Blades-
I decided that there was no way I could match the quality of a local tool shop.
They sharpen all kinds of blades, carbide saw blades.. everything.
Costs me 5 bucks a blade.. and they look like new. They did my 'wavy' mulching blades from my old craftsman before I sold it.
Find someone that has the right tools to do the job right.
JP
</font><font color="blue" class="small">( Blades-
JP )</font>
Not a bad idea but but not really necessary for such a simple task. Anyway $5 is steep for standard sized blades most shops are $3.
Slam
   / Blades you cannot sharpen? BAHHH!! #17
<font color="blue"> Anyway $5 is steep for standard sized blades most shops are $3. </font>
I lack the patience to sharpen chainsaw chains, so I have six chains (three for each chainsaw), and I take all of them to the local Sharpening Shop. He does all six at the same time for $18. /forums/images/graemlins/smile.gif
I think he still does blades for two or three dollars each.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
2018 KENWORTH T800 (INOPERABLE) (A53843)
2018 KENWORTH T800...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
