Blank LCD on 3240
   / Blank LCD on 3240 #1
reprosser
Midlands of South Carolina
I only have a few hours on my new 3240, but yesterday when I started the tractor, the LCD screen was blank.
Is there a switch to turn it off/on, or a connector that my have come loose? I checked the fuses, and they looked OK. The lights and signals all work.
   / Blank LCD on 3240 #2
That doesn't sound good. I don't think there is any switch for the dash display.
Have you tried just turning the switch on and off a few times to see if its a bad connection?
Good luck!
   / Blank LCD on 3240
I have tried the key switch multiple times, but it does not make a difference.
Maybe there is another fuse besides the set under the hood up front.:confused:
It was working when the tractor was loaded on the trailer, but after unloading it was blank. I am hoping a connector was jostled loose.
Have not had time to do any real troubleshooting - will take a closer look on Sat.
   / Blank LCD on 3240
I found out that the whole display is out :eek: - tach, LCD, indicator lamps - all except for the parking brake indicator.
Hope to get to work on it this weekend.
   / Blank LCD on 3240 #5
If it is new, let the dealer do it.
Otherwise, take out your wallet and open wide...
   / Blank LCD on 3240
So far I have found that the alternator fuse and the panel fuse are blown (and blow if replaced). I will try to run down the short tomorrow.
Is there a wiring diagram available anywhere for the 3240? Maybe a service manual?
   / Blank LCD on 3240
Display was replaced, and everything works now.:D The only issue is that the HST High (rabbit) and low(turtle) indicators do not show, and the HST "stall guard" indicator does not show. :(The High/Low works (I can feel the difference), but no indicator.
So, I am using the tractor and waiting to hear what can be done to fix the indicators.
Anyone else have/had this problem?
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
