Bldg/construction Question
   / Bldg/construction Question #11
I recently finished out the remaining area of our basement. I also used 2 x 4 stud walls with pressure treated plates, placed about 1/2 " off of the concrete walls. I then had an insulation company spray a 1 1/2- 2" layer of closed cell insulation directly on the concrete and behind the stud walls, followed by spraying cellulose out to the front of the studs. It cost about $1900 to cover 1100 + square feet, including spraying extra thick around the sill plate.
This is the most comfortable area of our home, and has me totally sold on using this method. I wish my whole house was done this way, but we didn't build it.
   / Bldg/construction Question #12
Spray foam or foam panels are good options.
   / Bldg/construction Question #13
If this is air conditioned space, that would really help prevent mildew and mold.
When adding A/C / heat to a den/room, you also need to add a return to the room. The return is what takes care of the humidity (so to speak). I've seen a lot of people just cut a hole in the duct to supply A/C & heat but, don't add a return
I do have a 1/2 to 1" space between the block wall and the framed wall.
   / Bldg/construction Question #15
you can insulate using rigid foam products and build your wall in front of it.
This is best option - otherwise use spray foam but that is more expensive
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2012 ADDCO S/A Towable Arrow Board (A52377)
2012 ADDCO S/A...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
