blew an hydraulic line - how to clean the tractor
   / blew an hydraulic line - how to clean the tractor #12
When I blow a hose on my tractor, I use my pressure washer and pressure washer degreaser from walmart. I use spray it on everything with the pressure washer, let it set for a few minutes then hose it off. But then, I am not too fussy about having a spit and polish tractor. I work it in dirt and dust and dont worry too much about a little dirt on it. But the pressure washer does a good job. Cat litter is cheaper than oilsorb material is does a good job on concrete. Simple green might work on the concrete after the cat litter has soaked it up a bit. I dont think you will ever get the stain out completely though due to the porous nature of the concrete. Just scrub it good and then keep some cat litter on it for a few weeks and it will continue to wick out anything that is left. Oil leaks in the garage is a good reason to put down an epoxy coating (before the oil is spilt)
   / blew an hydraulic line - how to clean the tractor #13
I've always used plain old mineral spirits mixed with kitty litter/absorboil on my driveway and concrete floors... no doubt it would could the oil on the tractor.. No need to complicate things.
   / blew an hydraulic line - how to clean the tractor #14
just had this happen myself.
I figure the tractor is now rust proofed for another 50ys.. I just cleaned the seat up where I need to sit.. that and thru my clothes away!
it's amazing how much surface area about 2g of UTF fluid can cover.
It's also amazing how fast 2g's of oil can exit a 3/8 line with a pencil sized hole in it!
soundguy
   / blew an hydraulic line - how to clean the tractor #15
Blowing a hydraulic hose is not an uncommon thing to happen. Usually you want to get going again as soon as possible. Wipe up as much oil with rags as you can and later you can try to get it better with a solvent if you want to. A lot of people's machinery is kind of dirty anyway.
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
378467 (A51572)
378467 (A51572)
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
Magnum 125 Generator (A53421)
Magnum 125...
2014 Freightliner M2 106 24ft Box Truck (A52377)
2014 Freightliner...
