Blew the spark plug right out of the head.
   / Blew the spark plug right out of the head. #1
JoelD 61
JD 455 JD 300 Ford 961
My new to me JD 300 just blew the plug right out of the head. Too warm to check the threads right now. Test drove it for just a few minutes before I purchased sounded good. First got it home and ran it around for maybe 5-10 minutes mowed for a couple more. Started making some ticking (not knocking) noises at front of motor. Popped hood saw more vibration than I like and suspected motor mounts. Shut it down and changed the oil as I do with a new/used vehicle. Pulled side panels and checked the motor mounts. Looked aged but not bad. Sat until this afternoon when I fired it up. After a couple minute warm up I opened it up and all sounds good. Mowed for a couple minutes and the ticking reappeared. Motor started running rough. Shut down blade. Was throttling down and POP. Cooling down now. I'll check the head and plug to see if there is any thing glaringly obvious. Anyone experienced similar? I would expect that if the plug was cross threaded I would have noticed a misfire. Didn't notice anything strange till the ticking showed up.
   / Blew the spark plug right out of the head. #3
May be try a new head and head gasket, it could be as simple as that
Thanks for the reply. Heard of helicoils, never used one. Just watched a video. Doesn't appear so. Looked like some head threads left in the plug threads. Not too bad but not promising either. Cleaned the plug threads and was able to install plug normally and snug it up properly. Started it back up. All good until again the ticking started. Is this possibly a symptom of overheating or possibly a head gasket? The engine is clean and i can see no reason for it to overheat.
   / Blew the spark plug right out of the head. #5
Ticking could be valves or valve train related (push rods, valve seats, valve springs, hydraulic lifters, valves themselves, rockers), could be head gasket leaking after heat up, or leak around or through spark plug.
Do compression test on engine, if it holds pressure above lowest spec value then do a leak down test.
   / Blew the spark plug right out of the head. #6
I'd pull the valve cover.. find out what the spec is on the valve adjustment, COLD & HOT..
Both good tips on the valve train. I have a service manual now so I can check spec's and hopefully get this figured out. Thanks for the ideas.
   / Blew the spark plug right out of the head. #8
Which engine is in the unit, Briggs or Koehler. The Briggs had a problem with the rocker arms coming loose and making a ticking sound. The Koehler had a problem with the head bolts loosening and allowing blow by at head gasket which sometimes sounded like a ticking noise.
I have the Koehler 341. Good info. Thanks I'll check.
   / Blew the spark plug right out of the head. #10
While it certainly won't hurt anything to check the valve train, I doubt that you'll find the problem in the valve train. Ticking can simply be directly related to a loose plug. Loose because there's an issue with the threads or loose because it was simply installed loose. If there is a compression issue of some kind it's a high compression issue not a low compression issue which would tend to lead you away from a head gasket problem. The spec for spark plug torque should be around 12 ft lbs or so ------ good luck. When you figure it out, let us know.
   / Blew the spark plug right out of the head. #11
If the threads in the head look bad, buy a thread chaser. Available at most automotive shops. Not very expensive and may help save the head.
Richard
   / Blew the spark plug right out of the head. #12
Did you check to see if the proper spark plug was installed? It could be the wrong reach (thread length).
Threads are ok. Slight damage not too bad. Correct plug. I was able to put it back in and torque it down with no issues. I will pull the shrouds later today and check the head bolts and valve clearance before I start it again. Really concerned about overheating. Don't want to have to rebuild this engine. I agree with the possibility of high compression. I understand these engines have compression relief making it hard to check. Not sure how to go about identifying/resolving a high compression issue. I've ordered a head gasket and will pull the head when it arrives. Hopefully answer a few questions upon inspection.
   / Blew the spark plug right out of the head. #14
You can download the K341 Kohler Service Manual in PDF format here. Scroll down to the section on the K series engines it is near the bottom. Free Kohler Service Manual Downloads - OPEengines.com
   / Blew the spark plug right out of the head. #15
Don't forget to decarbonize the head. These engines also have counter balance gears which have been know to give trouble. People usually remove the gears. If you are worried about overheating, use a good quality synthetic motor oil. Amsoil makes a straight grade 30w synthetic oil.
Thanks guys. Just received my manual on CD today. I'll look into the counterbalance gears. Valve lash and point clearance were both a little wide so reset them and head gasket will be in this week. Had to order the little grommet for the points cover as mine was disintegrating but there at least. Was kind of surprised to find them. Figured I'd be making my own.
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2006 Freightliner Auger Truck (A56438)
2006 Freightliner...
