Blew the spark plug right out of the head.
   / Blew the spark plug right out of the head. #11
If the threads in the head look bad, buy a thread chaser. Available at most automotive shops. Not very expensive and may help save the head.
Richard
   / Blew the spark plug right out of the head. #12
Did you check to see if the proper spark plug was installed? It could be the wrong reach (thread length).
Threads are ok. Slight damage not too bad. Correct plug. I was able to put it back in and torque it down with no issues. I will pull the shrouds later today and check the head bolts and valve clearance before I start it again. Really concerned about overheating. Don't want to have to rebuild this engine. I agree with the possibility of high compression. I understand these engines have compression relief making it hard to check. Not sure how to go about identifying/resolving a high compression issue. I've ordered a head gasket and will pull the head when it arrives. Hopefully answer a few questions upon inspection.
   / Blew the spark plug right out of the head. #14
You can download the K341 Kohler Service Manual in PDF format here. Scroll down to the section on the K series engines it is near the bottom. Free Kohler Service Manual Downloads - OPEengines.com
   / Blew the spark plug right out of the head. #15
Don't forget to decarbonize the head. These engines also have counter balance gears which have been know to give trouble. People usually remove the gears. If you are worried about overheating, use a good quality synthetic motor oil. Amsoil makes a straight grade 30w synthetic oil.
Thanks guys. Just received my manual on CD today. I'll look into the counterbalance gears. Valve lash and point clearance were both a little wide so reset them and head gasket will be in this week. Had to order the little grommet for the points cover as mine was disintegrating but there at least. Was kind of surprised to find them. Figured I'd be making my own.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
Duetz Power Unit (A50120)
Duetz Power Unit...
