Block heater time vs. temp?
   / Block heater time vs. temp?
Thanks for all the replies guys. I won't have to worry plugging in the block heater over night now. A cord reel that hangs over the tractor in the barn might be a good Christmas present from Mrs. Newblue!
   / Block heater time vs. temp? #12
For something in the range of $10-15 you can purchase an outdoor grade timer, capable of 15 amps. I used one on my 1 hp pool pump motor for over 10 years. Very nice yet very simple.
   / Block heater time vs. temp? #13
I almost hate to muddy the water on this topic, because living in Wis I will probably end up with a heater. But from the aircooled engine world of airplanes, the concern with extended operation of a heater that only heats the crankcase, moisture is driven out of the oil in the crankcase and condenses in the unheated cylinders - potential for corrosion. For the plane, I run the heater for an hour, for the tractor, I will probably do the same, with a timer.
   / Block heater time vs. temp? #14
Above I commented on my use of block heaters. At my work we have 2 Cummins 6 cyl diesel fire pumps. Each has a continuous block heater that maintains 120 F, in spite of being in a heated building. We have a minimum start temp of 100 F for non-emergency starts. With a 20 year maintenance history it is documented that cold starts increased engine wear. But, keep in mind these engines start at full load and go immediately to 1800 rpm.
   / Block heater time vs. temp? #15
<font color="blue">of a heater that only heats the crankcase </font>
The standard NH block heater does not heat the crankcase, it heats the coolant.
   / Block heater time vs. temp? #16
I have a TC24DA w/dealer installed block heater,
Below freezing, I plug it and walk away. Always ready to go whenever I need it.
   / Block heater time vs. temp? #17
I would think you are contributing to the breakdown of the coolant prematurely and possibly other heat-related deterioration by having it always plugged in. ... maybe I'm wrong? /forums/images/graemlins/confused.gif
SET OF TRUCK FENDERS AND HARDWARE (A58374)
SET OF TRUCK...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2000 HAULMARK K716BT-WT 7' X 16' CARGO TRAILER (A52708)
2000 HAULMARK...
Club Car Utility Cart (A55853)
Club Car Utility...
LOT OF WOOD FLOORING (A58374)
LOT OF WOOD...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
