Pilot
Veteran Member
- Joined
- Nov 20, 2004
- Messages
- 1,219
- Location
- Oregon
- Tractor
- JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
After years & years, I have finally figured out how mice are getting into & under the house, thanks in part to a ground squirrel that got under the house. There is a little gap between the furnace and the garage foundation. Somewhere behind the furnace there must be access. But I can't get to it. Access to that area for humans is blocked by a water heater & a well pressure tank.
This week, the pressure tank is getting replaced, so for a brief period I'll have some access. So how can I best block that gap behind the furnace and do it quickly so the tank guy isn't delayed too long?
My first idea is to squirt in insulation foam, the kind that comes in pressure cans. I figure if the mouse doesn't see an entrance, he won't go there. Have also thought about wadding up some metal window screen material and jamming it in there and maybe using the foam along with it, so if for some reason they get thru the foam or it disintegrates over time the screen will block access.
Any better ideas?
Thanks.
Any better ideas?
Thanks.
