bigpete
Ouch. Shear pins/bolts are supposed to be the weakest point in a drive assembly--for any powered assembly (but all you guys knew that anyway). What happened to you is the exact reason for the existence of a shear pin. By putting a Grade 8 bolt in there, they made your engine's output the weakest point in the powered assembly.
Bolts are cheap. If the manufacturer's specs still results in the problem, I would recommend starting with the lower grades and working your way upward. I'm sure you will be annoyed by having to replace them under low load levels at first, but you will find the sweet spot pretty quickly. If for some reason your TC24 is not creating the PTO HP up to spec and still won't shear the bolts, you have a bigger problem. That is highly unlikely, though.
Grade 8 and better are used in applications where a bolt needs to supercede most all other possible points of failure. I can't believe they shipped the blower that way.
Ouch, again /forums/images/graemlins/crazy.gif
