Gittyup
Elite Member
- Joined
- Oct 4, 2007
- Messages
- 3,145
- Location
- Mid Atlantic
- Tractor
- Kioti CK25 Shuttle Shift, loaded tires, JD X739
I may have a blown head gasket. A lot of gurgling in the coolant reservoir and I've had to add about 1/2 gallon of coolant even though the tractor has just been sitting. Temp gauge, until now, has never risen above second dot at center of gauge. Now it goes up pretty high (not to red) and then comes back down, which looks like the thermostat opening. Then is stays down. Oil looks normal and was changed in last 20 hours or so. It's not cloudy, nor increasing in height. radiator hoses are soft, even when warm. There is no fluid leaking, that can be seen anyway. No white smoke. A little black smoke puff on startup is all. Engine sounds strong and normal.
As long as the temperature stays down and everything else is normal (besides the gurgle), is it OK to use the tractor? Or should I just shut it down and take additional troubleshooting steps. Could it be something else?
Appreciate any advice.
