Blown Head Gasket
   / Blown Head Gasket
Did not check for water pump free wheeling. How do I do that. Water hose didn't suck flat although I am replacing it. Have already replaced it once.
I'll check around and see if I can find a shop that can grind the old one just to have on hand. Pat
   / Blown Head Gasket #42
If you can't get to the impeller via the hose spout/s to hold it with a piece of wooden dowell/paint brush handle whilst turning the fan a little to see if it loose , i would take the time to remove the pump to be certain . To me you have not found the cause , if the machine shop was not concerned with the marks on the head i would be investigating further . It would be a shame to have it happen again not to mention inconvenient whilst the harvest is on . As i said in an earlier post here , a loose impeller will cause intermittent water flow and cause the water in the block to boil without being imediately apparent at the cap as the water in the radiator would be cooler as it is not flowing through the block .
   / Blown Head Gasket
So we broke off an injector trying to remove them. Ordering a new one today. Just another delay that was not expected. Guess I should start expecting delays so I won't be disappointed. Pat
   / Blown Head Gasket
Sorry about that, it wasn't an injector it was a glow plug!!!!!!
   / Blown Head Gasket
I haven't been able to post for over a week. Will catch you up on what's happened. We got the glow plug and installed in the new head. We started to install the injectors and realized that we needed crush washers for them. Another delay to wait for them. Ordered the crush washers. Put everything together last night. Tractor started without a problem. My son-in-law was going all over the motor checking for oil leaks and told me to shut it down. There was oil coming from a hole in the back of the head. The old head had a hole but it is plugged. Don't know why the hole. Will call the dealor in a while after they open. Another delay and I sure need to spray my peach trees.
   / Blown Head Gasket #47
Bummer.
Does the oil hole have pressure? Or just a drain plug. If no pressure then put a temp plug in there and test it out. If it's threaded then remove the old plug and reuse.
In the future you can get away with reusing the injector washers if they are not torn up. At least get you running and replace later. Been there done that.
Rob
   / Blown Head Gasket
There was no pressure on it. The hole wasn't threaded. It is smaller than a pencil. We loaded a small threaded bolt with JB weld and tapped it in, after putting some JB weld in the hole first. I'll let it sit over night and fire it up tomorrow.
I think we found the problem that caused it all. The fan belt had not been replaced. The tractor is 5 and 1/2 years and it had been adjusted all the way out, couldn't get any tighter. You could turn the fan with your finger with little resistance. The belt showed signs of slipping on its sides. Needless to say there is a new belt on it tonight. I hope to take better care of the tractor now that I am retired and not working 10 to 12 hours per day. Thanks to everyone for helping me out, I'm sure I will need you again. Now I can go mow the field and spray some peaches.
   / Blown Head Gasket #50
I have been following this post for quite a while because I was very curious about what was causing the problems with your tractor, because I have a KAMA 354 diesel. Do you mean that all of these problems were caused by a loose fan belt?
In the past I have almost pulled my hair out trying to figure out what was wrong with my Ferguson TO-30, my Dad's Farmall, my brother-in-laws' Cub Low-Boy and another brother-in-laws' Ford 9N. All of these problems wound up being an easy fix for a very elusive problem. If your problem was a loose fan belt, I would have to say that this really has topped them all.
I hope that you have solved your problem and that you have many years to enjoy your tractor without any further problems.
2018 FORD EXPEDITION (A51406)
2018 FORD...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
Komatsu PC138 (A50490)
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
