Blue screen pc
   / Blue screen pc #11
Here is one trick that may get your drive to start one last time. Pick up the cpu and rotate it fast back and forth in the same plane as the disks in the drive, hopefully this will get the drive off the dead spot and it will spin up. Caution this may work one or two times but the drive needs to be replaced. If you are not afraid to open the case you can remove the drive and do the same rotating, its easier when its out of the case. Good luck!
   / Blue screen pc #12
If the problematic drive spins up...the easiest way to recover data is to simply boot the system to a "bootable CD" AKA a "live CD"
Almost all Linux distributions have live cd options...just download and burn the ISO to a CD or DVD...
on the problematic machine...make sure the CD/DVD drive is set as the first boot device in the bios...then just put the live cd in the drive and boot it up....once you have a desktop mount the drive and copy data to a thumb drive or external hard drive etc...
   / Blue screen pc #13
"I'm switchin' teams, to a Mac."
I chuckled at that! Doing so means you'll pay twice as much for less of a machine that will have the same problems in the long run!
BSOD is usually a software issue and not a hard drive issue. But if it is your hard drive all your data can easily be recovered, short of your platters exploding! I have literally dropped HDs on the carpet from a foot or so to jar things enough to get it working again. Another great way is to remove the drive and stick it in the freezer for 30 - 60 minutes then re-install it. Using an ATA or SATA external drive is good but they can fail too!
I'd suggest you save your money, buy a new solid state hard drive (no moving parts to fail), put it in your old computer and have someone recover your old data. Then look into installing Peppermint 4, Linux Mint or even Ubuntu operating system. These Linux based OSs are all FREE and can run 99% of all Windoze software, are more secure and efficient that either Windoze or Apple. It might take a day to get used to a new OS but you'd be happier in the long run and you'd save big money.
I currently use an eMachine that is 10 years old, run Peppermint 4 OS and keep all my info and data on a SSD external hard drive.
Just an opinion from a guy who has built and repaired computers since 1997.
Good luck!!!
~GM66
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
(4) Painter Hoppers (A50121)
(4) Painter...
