Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
If you can't replace the window and you can't nail or screw into the siding/framing beside the window, I'd remove the window and cut a piece of plywood a little larger than the opening and use a carriage bolt thru the plywood in each corner so that it is inside the rough opening and use a 1x on the inside in each corner that the bolt goes thru and put a washer and nut on it. If need be, you can also use a foam gasket on the top and sides of the outside plywood for a better weather seal. That way there are no holes in your building and is about as secure as you can make it.
Good answer. Short of replacing the window, this seems to be simplest.
