Bobcat 324 Question...what these two bolts?
   / Bobcat 324 Question...what these two bolts? #1
mykubota4x4
Kubota B3030HSDC
Hey Folks
Being new to the machine, wanted to change oil & a tech at bobcat suggested there is a drain plug, I went n loosened one of the two bolts only to realise its a dry one (kinda spring loaded) & now i cant put it back. Any idea what this bolt is for. There are two of them in like 3-4 inch apart under that metal frame right below the engine.
BTW Oil change on these were through the hose at the back with a CAP nut (22mm) which i found out thru Youtube. Thanks in advance.
   / Bobcat 324 Question...what these two bolts? #2
Take a look at the 324 pages on Bobcat Parts Online for the upperstructure and see if anything looks familiar. I'd thought it might be for the rear door latch, but that shouldn't be under the engine.
I wonder if its part 4 or 5 in the above diagram of the track tensioner. From what i see the 2 screws were one behind other (with ref to front to back of machine placement)
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
City of Lakeland (A51691)
City of Lakeland...
FUTURE FT800 REMOTE CONTROLLED LAWN MOWER (A52706)
FUTURE FT800...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
