Bobcat 334 Bucket Teeth
   / Bobcat 334 Bucket Teeth #1
Mainah334
The teeth on my excavator are worn quite bad and need to be replaced. I can see that there is some sort of pin holding them on, but am not quite sure how to remove it. Can I just drive this pin one way or another or does it screw in? Thanks in advance for any help.
   / Bobcat 334 Bucket Teeth #2
Most of the pins drive out.
   / Bobcat 334 Bucket Teeth #3
It is a roll pin, a rolled up tight coil of steel that was driven into place. I advise soiking them with penetrating rust oil, beating crap out of the tooth and driving them out with a sledge and punch from either direction. You may have to work it both ways. Drive the new pins in with a hammer and punch, and yes you must get new roll pins. Id advise doing it on the machine with the teeth at chest level. Wear ear protection as the bucket acts as a massive echo chamber. Did three changes on my old kx121 this way, good luck.
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
