Bobcat 632 engine oil milky
   / Bobcat 632 engine oil milky #1
rooster0975
Waupaca Wisconsin
Bobcat 632
I have notice a small milky color on my dip stick. The engine is a ford four cylinder and was apparently completely rebuilt? This runs great and does not blow white smoke of any kind. I did change the fluid and the problem is not going away? Any thoughts or suggestions? The Bobcat is a 1980
   / Bobcat 632 engine oil milky #2
Either water or antifreeze must be leaking in there. Is the volume of the oil increasing a bit? Two problems come to mind. 1) small crack in the engine block. or 2) a blown head gasket. Is it kept outdoors? Rain water getting in there some how? Just a few suggestions...
   / Bobcat 632 engine oil milky #3
Unfortunately, Harry is right and milky looking oil is a product of oil trying to mix with water. If the problem comes back quickly, there's a pretty substantial issue. The best thing to check with this would be to run a cooling system pressure test. You can get a tester from AutoZone for free (their tool 'rental' program). It should hold consistent pressure for 15-20 minutes. If not, it's the perfect way to find any coolant leaks.
I appreciate the advice...I will do it this weekend. The machine always stays indoors.
   / Bobcat 632 engine oil milky #5
If the engine was "just" rebuilt. and you're having this problem, I would say someone must have messed up a bit!
By the way, my grand parents had a cottage in Waupaca. On Minor Lake. Great memories there. Silver Lake too!
Thats and awesome chain of lakes for sure. I agree...I noticed this in the summer awhile back just a small bit on the dip stick...seems to be getting worse. I do not see any milky stuff on the filler cap at all. I'm sure I will have a head gasket problem.
20702 (A51694)
20702 (A51694)
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
John Deere 3032E with loader and Box Blade (A55314)
John Deere 3032E...
CAT 416B (A47477)
CAT 416B (A47477)
