Bobcat 763 - moves by itself
   / Bobcat 763 - moves by itself #1
Zurpro
Calgary AB
montana
lately the unit starting to move by itself - levers are in center postions - cannot stop unit- have to keep moving levers back and forth to stay in position !!
   / Bobcat 763 - moves by itself #2
There is an adjustment for that down back at the pump. Cam rollers on the pump arms push against blocks fastened to the return spring plate. Cam rollers get worn then need adjusting. Procedure is in the Operation Manual, if you don's have on I suggest you get one. It is a little to detailed to post on here.
Thanks for the info :)
Funnel Fans (A47369)
Line Striping Equipment (A44571)
Line Striping...
2025 Wolverine TR-26-02C Class 2 Quick Hitch (A47484)
2025 Wolverine...
Toro Z Master 5000 60in Zero Turn Mower (A44572)
Toro Z Master 5000...
2018 Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A46877)
2018 Kubota BX2680...
2025 Wolverine LHR-TWP80 Semi-Trash Water Pump (A47484)
2025 Wolverine...
