Bobcat 863F valve lock on, no tilt or lift
   / Bobcat 863F valve lock on, no tilt or lift #11
Always a volt meter. A test light can fool you. Should show battery voltage. In you case your looking for continuity between the BICs coil and BICs controller. I'm also curious. When you made the original repair.(actuator)Did the snake eyes light up or flash. I'm betting the problem is in the SSLs harness not the AHC.:thumbsup:
   / Bobcat 863F valve lock on, no tilt or lift #12
Did a little more digging in the tech man. Found an obscure note about using the correct BICs controller for AHC machines. I think I saw you post that you replaced it. Confirm you installed PT# 6674225. Also check continuity on wires between BICs controller and Bobcat controller(metal box one) These are your power and signal wires. 1.Yellow/dark blue 2. purple/white 3. purple/red. Also check plug on these 3 wires between controllers. :thumbsup:
378484 (A51572)
378484 (A51572)
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52576)
2005 INTERNATIONAL...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
2017 INTERNATIONAL PROSTAR (A52472)
2017 INTERNATIONAL...
CAT FORKS W/ QUICK COUPLER (A52472)
CAT FORKS W/ QUICK...
