Bobcat A220 new SSL
   / Bobcat A220 new SSL #1
jgh
Goochland & Fluvanna Counties, VA
NH TN90F; B3000 Kubota; Bobcats 430 & A300; Liebherr 621C, Exmark laser Z, 2 sawmills
20020303
I would love to know if anyone knows anything about this new 'Cat. Local dealer loaned me one and wow, who needs a tractor!
Jim
   / Bobcat A220 new SSL #2
I'm a bit partial to the "real" Cat, so I'd better stay out of this one...
   / Bobcat A220 new SSL #3
I always thought if Bobcat (or anyone else) could put an optional 3pt lift and rear PTO (hydraulically driven) on a skidsteer, they would replace most compact tractors. The front end of a skidsteer is light, but if the wheel base was extended slightly and get the engine placed just ahead of the rear axle, it would probably work. I would certainly buy one. Do just the rear wheels turn or can all 4 turn? Wheels that turn would eliminate a lot of the issues of tearing up the ground/turf.
   / Bobcat A220 new SSL #4
They are smooth, but I will keep my compact as for what I use mine for, the CUT is much, much easier to get onto (into) and off of (out of) than a skidsteer. Also, the larger tires make for a MUCH smoother ride. But each has its place, I am sure.
   / Bobcat A220 new SSL #5
My main concern would be getting belly hung in mud or snow,for I seen this before..yikes /w3tcompact/icons/frown.gif
Ice would be another factor on a slope w/out all 4 tires chain up.
   / Bobcat A220 new SSL #6
Saw my first 220 the other day, ran it around the yard a little seems like a real smooth unit, but thats more electrical and hydraulic controls to mess up lol.
Now they have the A300, a larger version of the AWS concept. I'm still trying to sell my NH to buy the A220, but this one seems like more/better, with 3000# ROC, vertical lift path, etc. Same engine, slightly wider, heavier, etc.
Does anyone know why it shows no Hi-flow aux hydraulics option? I noticed that is also applicable to the 963, biggest hoss in the stable there. Seems odd as HD as these are!
Specs are at:
http://www.bobcat.com/
Jim
   / Bobcat A220 new SSL #8
Not sure on the hi-flow option, may be they dont have room for a bigger pump needed for the hi-flow, its getting crowded in there, they already use a much larger hydrostatic pump than they used to, but at the same time it seems drive pressure is lower than the non-AWS models they dont seem to dig nearly as well as the skid-steer only models (in my opinion) but I dont have near the hours on the AWS as I do the skid-steer.
Re: Bobcat A220/300 new SSL
20020529
Just got word that the 300 will replace the 220 for Bobcat. Apparently the price and dimensions will be so close that it makes no sense to sell both.
Hopefully the added ummph will answer some of Gatractorman's concerns about digging.
Salesman was not sure on the Hi-flow thing, said he would check.
More when I know it.
Jim
   / Bobcat A220 new SSL #10
Hey Jim, I've not heard that rumor but there is quite a difference between the two, same engine and pump package (no the 300 wont dig either LOL) the 220 has radius lift boom arms and 2200 lb. operating capacity hence the 220 designation, the 300 has vertical lift boom arms and 3000 lb. capacity.
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2000 FORD F-350 SUPER DUTY (A50854)
2000 FORD F-350...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2016 MERCEDES-BENZ GL-Class (A50324)
2016 MERCEDES-BENZ...
Sakai TS160 TTS5 Pneumatic Asphalt Roller (A49461)
Sakai TS160 TTS5...
