Bobcat CT2025
   / Bobcat CT2025 #1
klw_pitt
Pittsburgh
Bobcat CT2025
First time changing my oil in my CT2025 and want to make sure I get it right. Does 3 quarts of 10W30 sound on par? Also anyone know the filter part #
   / Bobcat CT2025 #2
I plan to look in my owner manual when I do mine.....
   / Bobcat CT2025 #3
Isn’t that a rebadged Kioti? You may be able to find some info for that tractor?
   / Bobcat CT2025 #4
The Kioti is the CK2610. The 3010 takes 6 quarts, so I think 3 is a bit shy
   / Bobcat CT2025 #5
Looks like the Kioti, with the same motor, uses 6qts. 3A165LWM was the motor in both the Bobcat and Kioti
   / Bobcat CT2025
Thank you ended up going to dealer they recommended 15w40 and had the filter. Misplaced my manual so thank you for the help. Watched a video on YouTube on an oil change on 2610 should be good to go now 👍
2017 Jaguar XE 25T Sedan (A44572)
2017 Jaguar XE 25T...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A44391)
New/Unused 7ft 20...
1996 Monon 45X96 Dry Van Trailer (A46877)
1996 Monon 45X96...
INOP/NON-RUNNING 2007 International 9200i Truck, VIN # 2HSCESBR07C488107 (A44391)
INOP/NON-RUNNING...
Titan Contractor Series Post Hole Driver (A45336)
Titan Contractor...
Whiskey Barrel (A44391)
Whiskey Barrel...
