BobcatTR
Will my 27hp CT225 run a 5' bushog?
Looking at buying one.
Width on tractor is 56"
Thanks Terry
Thanks Terry
Thanks for the reply Winston.Depends on what you are mowing. Heavy stuff, no, light stuff yes. And you don't have to cut 5'. I ran a 5 footer on a Yanmar 20 pto hp for several years. Just have to use good common sense in doing it.
Thank u for that info!I run a 5' bush hog on my 28hp Montana. Cuts 3' grass no problem. See if you can rent or borrow one to test on your tractor.
Excellent ADVICE thank u! I purchased a nice used one, anyway! Just picked up last nite. Going to sharpen blades, and try it out.I have the identical CT225 and run a 4' cutter only because I had it before getting this tractor. Majority of the time I could easily run a 5'. I can get tractor to start lugging pull down in tall heavy grass if I am running in 2nd (Mid) gear range and travel the same speed in Low without engine lugging down.
Just an operational tip; Full travel speed in low is same travel speed as 1/2 pedal in M and seldom, if ever, do I want to travel any faster than that cutting. The difference in torque loss through the gear range in M vs L put more HP load on the engine. Also the transmission runs slightly cooler due to lower pressure required in HST pump.
When u run it, full engine RPM?
Or, run it where the DIAMOND is?
Can't remember the DIAMOND RPM!
thanks Terry
