Bobcat CT445 over heat
   / Bobcat CT445 over heat #1
bmillerag
Flat Rock, Indiana
bobcat ct230
I have a problem with my temp gauge showing my tractor is over heating. I have already replaced the thermostat and temp sensor. It doesn’t show that’s it overheating all of the time. Only when it’s warm outside above 70 degrees and even then it doesn’t happen all of the time. I used a temp gun on the block and other components and they don’t seem to be hot. I don’t get and smell of antifreeze either. I can run two or three hours and be fine then all of a sudden it starts to creep up. Any ideas
   / Bobcat CT445 over heat #2
Maybe just a bad sending unit. My CT235 pegs out when I turn the lights on, never figured out why. I just don't worry about it and other than sometimes loading it in the dark I never use the lights. If your temp gun is not indicating overheating when the gauge pegs out then no worry but I'm sure you would like to know the fix.
Bobcat 6697627 Search results for: 'engine components 6697627 engine temp sender' | Genuine Bobcat Parts
Kioti e7240-32731 E7240-32731 - Water Temperature Sender for Kioti | Up to 60% off Dealer Prices | TractorJoe.com
   / Bobcat CT445 over heat #3
I know you said you’re not Reading hot with the separate thermometer but have you checked and cleaned a radiator screen?
I have changed the temp sensor already and cleaned the radiator screens.
2012 CAT D5K2 Dozer (A42203)
2012 CAT D5K2...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2016 Ram 2500 Pickup Truck, VIN # 3C6UR5CL0GG391142 (A44391)
2016 Ram 2500...
2000 Mack CH613 w/ Wetline Truck (A42203)
2000 Mack CH613 w/...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A44572)
2017 Ford F-150...
STORAGE FEES (A43003)
