Bobcat E35 engine question
   / Bobcat E35 engine question #1
t1kilo
Bronze Member
Deep in Cajun country
JD 5085E
I'm looking at purchasing a Bobcat E35 Mini-ex in the coming weeks from a buddy of mine. It's a 2016 model with the 33 HP engine. The engine is tier 4 compliant, but for the life of me, I can't figure out if it has a DPF or not. I know that it doesn't use DEF, so that's a positive. I looked over the engine, and I can't see anything in the exhaust system that has wiring running to it, so it leads me to believe that there is no DPF. The engine is a Kubota D1703-M-D1-E4B from what I've been able to pull from my internet searches and conversations with AI.
Does any of you have this machine, or another one with the same engine, that can give me a little more information about the emissions and what to expect? I would really appreciate it.
   / Bobcat E35 engine question #2
I have a 2023 or 24 E35.. No def fluid
Does it have a dpf and need to regen periodically?
2006 Ford Crown Victoria Sedan (A50860)
2006 Ford Crown...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
TRUCKING INFO (A50775)
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
Craftsman Lawnmower (A50860)
Craftsman...
