Bobcat hydraulic oil leak
   / Bobcat hydraulic oil leak #21
It takes a quality transmission/hydraulic fluid. Bobcat recommends using their fluid but I know several on this forum including myself have had no problems using Tractor Supply's Traveler brand. I can only guess where your leak is. The loader valve has what is called a bolt joints that attaches the hydraulic lines to the loader valve. Notice reference numbers 8, 13, 17. These are gaskets for those joints. "If" is is leaking at one of them it might just need tightened.
Here are the part numbers for the image in post #2 You can find this under "Accessories and Options" in the Bobcat Parts book for the CT235
Ref Part Number Description Qty Actions
1
JOYSTICK, VALVE ASSY
JOYSTICK, VALVE ASSY,NLA - W/Walvoil valve - Ref. 2-25 - Order 7199760 - Was 7150491
1
1 7199760
KIT, JOYSTICK VALVE
W/Hydrotech valve - Ref. 2-25
1
2
VALVE ASSY JOYSTICK
VALVE ASSY JOYSTICK,See Illustration "Joystick Valve GROUP(HST)" / CT230H-T750A,- NLA - Order individual components - Was 6697766
1
3 6697683
SUPPORT, JOYSTICK
1
4 6695575
BOLT
3
5 6697775
WASHER SPRING
3
6 6695517
BOLT
2
7 6697744
TUBE HYD
1
8 6694137
O-RING
2
9 6696165
BOLT JOINT
1
10 6694136
O-RING
1
11 6697054
BOLT
2
12 6697734
TUBE J2 HYD
1
13 6694137
O-RING
2
14 6696165
BOLT JOINT
1
15 6694137
O-RING
2
16 6696165
BOLT JOINT
1
17 6694137
O-RING
2
18 6697733
TUBE J RETURN
1
19 6695562
BOLT JOINT
1
20 6697360
HOSE, RETURN
1
21 7000814
CLAMP, HOSE
Was 6694674
2
22 6695525
BOLT
2
23 6697774
WASHER
2
24 6697775
WASHER SPRING
2
25 6986753
INSTRUCTIONS
Thanks again!
2008 FREIGHTLINER M2 FLATBED (A50854)
2008 FREIGHTLINER...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
